Question about Whirlpool Dryers
DRYER NOT WORKING. MODEL #LGR7646JQ0, SER #MK4629649, PURCHASED 11/18/00. PROBLEM: DRYER COMES ON HOT AND QUICKLY (ABOUT 5 MINUTES TURNS COLD) IF I WAIT ABOUT 2 HOURS AND TURN IT BACK ON IT REPEATS HOT AND THEN COLD. CAN'T FIND A SCHEMATIC TO SEE PARTS LIST. CAN YOU HELP? THANK YOU.
  • 246 Answers
Http://www.searspartsdirect.com/partsdirect/retrieveModelAction!retrieve.action?modelNumber=LGR7646JQ0
This should show you a parts break down for the unit. You can also find a schematic in the console (usually about 6 1/4" screws from the back of the console). As far as your problem, overheating could be causing it. Run the unit without the vent attached and see if the problem persists. If the unit keeps running, you'll know you have a venting problem. If the problem persists, I would usually replace the gas valves (usually one goes bad and won't hold open). These would be availible from a local appliance parts store.
Posted on Jul 09, 2008
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
Ive changed the ignitor, sensor, thermostat, fuse-thrml, and thermostat-fix.. my dryer still is only heating for only 5 min then goes cold. what can i do? model: LGR7646JQ0
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
Nov 11, 2010 | Whirlpool LGR7648KQ Dryer
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
I have a whirlpool LGR7646JQ0 gas dryer..the burner shuts off?
Sounds like you have a bad warp switch. Also could have a gas valve going bad.
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Dryers Logo
231 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
