Question about GE WBSR3140DW Top Load Washer
What causes a ge profile washer top load not to shut off water and moreless has a mind of its own
  • 1,557 Answers
Not shutting of water is a common fault there is a problem with your water level indicating valve in most cases the pipe has a block or has a nick in it leaking air the last problem is normally the valve so check that the valves hoses are connected at both ends try blowing the pipe out and make sure there are no nicks in the pipe
best of luck
Posted on Jan 02, 2011
Faulty stop pause button on ge profile wpre8150
This is caused by a faulty control board. The button you referred to is part of the board and the control board manages all aspects of the wash cycle. You will need to replace the control board. Here is a link to the part you need.
Oct 13, 2012 | GE Profile WPRE8150K Top Load Washer
GE WPRE6150 -Shuts down
4 flashes = Overfill fault presure pipe blocked
Check for high water pressure to unit, usually an indication of a bad water inlet valve.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
Water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile Top loading Washer Model # WSSR3120W1WW ---
The water diverter could be plugged. or the diverters solinoid has gone bad on the hotwater side. It is located on the diverter itself.
Feb 10, 2009 | GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Oct 27, 2008 | GE Profile WPRE6100G Top Load Washer
GE WBSR3140DW Top Load Washer Logo
319 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
