Please read description carefully about error code
Logik Washing Machine Error 21: "E21" Error Code Definition: Washer has not drained in allotted / time washer not draining. How To Clear Error Code: -Check that filter is not blocked or kinked -Check drain hose is clear of any blockage or kinked -Check wires to drain pump -Check drain pump is not faulty -Check level sensor and switch -Check wires to level sensor
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
This code (E3) means an error code. That the dishwasher electronic control
has detected a condition it needs to check. When you see a code, follow
these steps to solve the problem:
Press "Stop/Clear" to clear the display and stop the beeping if noted then .
Reprogram the Washing Machine.
If the code still displays, turn off the power to the
Washing Machines at your breaker box and wait five minutes and clean all part
(area) that are open to water carefully before turning it back
on for operation.
to clear the error code: whilst holding the pre wash and short wash buttons in together turn the control knob from off to gentle spin, this will clear the fault code and run a LED test. (if all goes weel) F9 means carbon brushes need to be replaced
Some washer and dryers will clear the codes by unplugging the machine from the wall.... Leave it unplugged for 30 secs... then plug it back in..... may clear code..... and may unlock door so you can get the clothes out.
Unsure of the code meaning.... but if you clear it by power down and it works don't worry about it unless it returns quickly.....
we need the code
I have code F-11 on my machine
