Question about Kenmore Refrigerators
When is ice maker activated ;with bar up or down ??
    President:
  • 1,102 Answers
The bar will sense ice cube level in the holding bin. If it is all the way down it will tell the ice maker to make more ice. When the maker "dumps" the ice the bar should be all the way up and will lower to check the level.
Posted on Jan 02, 2011
  • 1,557 Answers
Down as the ice fills the amount of ice building up pushes the bar up shutting of the ice production
sonic boom
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Ice cube maker just stopped working. Ice cube arm has no tension to it.
If you can find someone that will take yours apart and rebuild the components inside the front of the ice maker would be good. The problem is with older ice makers you may over look the next part to fail. Your model has a tricky spring that helps the arm lock into place. You can visit our site or call the toll free number and get free help and advice. If you can locate your refrigerator model number that will also be helpful Their numbers always look like this for example 213.54698
Click link below and give us a visit, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 23, 2009
smartr10U
  • 1305 Answers
SOURCE: how to make the ice maker work on my whirlpool side x side refrigator there is a bar above the ice box dispenser should it be up or down?
when the bar is up...it's off..
it's a sensor that will lift up as the ice tray gets full... otherwise you might have a freezer full of cubes!
So if it's up, it's off...
Cooooooool huh?
Sorry for the pun... but it's Sunday!
K
Posted on May 31, 2009
Kitchenaid icemaker will not shut off when bin is full of ice. Model: KUIS18NNXSo
Is there a wire/bar that goes across the ice bucket? As ice fills the bar raises up and eventually goes high enough to shut the maker off until the level goes down.
You can manually lift the bar up to ~ horizontal until it clicks in place and stays there. That should shut it off until you move it back down. If there is no bar, then I guess there in no way your ice maker knows when it is full and keeps producing. Perhaps the bar was removed, bent or broken off. At least tht is one type of ice maker I'm familiar with. Other types my have different ways to tell the maker it's full.
Mar 12, 2018 | KitchenAid Refrigerators
Ice Maker bar won't come down
I have not worked on this model before but on the whirlpool they have a bar as well. you can turn off ice maker by pushing it up and it locks in place to stop ice production. if u want it to make ice u push it up slightly and it should move down. also check the ice maker tray to be sure u are getting water to the tray. if u get the bar to go down and no water comes in then check that u have water at the back of fridge.. if u have water there but not in the tray then you may have a bad water inlet valve on back of fridge.
Apr 15, 2014 | Maytag MFX2570AEM French Door Freestanding...
The ice maker does not work on my new french door refrigerator the water is connected and turned on
There is a wire bar over the ice bin that flips up when the ice bin is too full. When this happens, the ice maker shuts off and you have to flip the bar back down to restart it. Have you checked that this high level bar is flipped down?
May 16, 2010 | Whirlpool GD5SHAX Side by Side...
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Ice maker will not stop sending ice out of door
If your refrigerator has a wire bar that raises and lowers as ice cubes are ejected. Make sure the bar is not trapped or frozen in the down position. This will cause the ice maker to continuously make ice.
Usually pulling the wire bar all the way up the ice maker will stop.
If not, you may have a bad switch and will need this replaced.
Oct 18, 2009 | KitchenAid Refrigerators
The icemaker won't make ice.
Try this,Open the freezer and look at the ice maker,there is a bar above the ice bin that kinda looks like a piece of metal coat hanger,Push it to the down position.If it is already down,Post back
Please take time to rate this fixya
May 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker has stoped making ice. The bar that cuts it off when enough ice is made moves a little while in the up position.
lifting the bar to the full up position is how you stop the ice maker from making ice. move the bar back down and ice making will resume.
Mar 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
LG Refrig ice maker on model LSC27950 overflow bar i think is stuck in one position because it made to much ice and jammed it up. now no ice is being produced
you lift the bar up to shut the ice maker off . or the ice fills and shuts the ice maker off . simply push the bar back down to star the ice maker in operating again
please rate solution thanks
Oct 19, 2008 | Refrigerators
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
2,797 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
