Question about Kenmore 24932 Top Load Washer
Kenmore 70 series will not spin all the water out of the clothes
  • 1,557 Answers
There is a fault with your spin cycle speed this is normally an internal gearbox fault
Posted on Jan 02, 2011
JOE LLAMA
  • 26 Answers
SOURCE: kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Posted on Apr 04, 2008
jsrock516
  • 5911 Answers
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
Posted on May 15, 2008
AlmostBob
  • 550 Answers
SOURCE: kenmore 70 series won't spin
If the washer makes a noise from the front bottom center, when not agitating and not spinning, the motor/gearbox coupling has broken.
closed2a0a669.jpg open7976f3d.jpg It is designed to break, if the load gets enough that the motor may be damaged and is simple (enough) to replace
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models but close enough, some have 2 clips some 3
  • remove screws under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips at rear corners
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Posted on Oct 31, 2008
asish_shrm
  • 121 Answers
SOURCE: Kenmore 90 Series Washer
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Posted on Nov 12, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 70 Series Washer won't spin or drain
DO NOT by pass a lid switch. It is installed as a designed safety feature to prevent bodily when opening the lid from moving parts. The CORRECT solution is to replace the switch. The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Replacements can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best deals. The first two web sites have excellent exploded view diagrams of your appliance to aid in parts location and assembly.
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
PS This is not a difficult repair and it doesn't cost much ($25 to $35) on average for a replacement switch. Begin, fisrt by making sure the switch isn't loose or the lid strike (if equipped) isn't broken off. You may not need parts.
Posted on Jul 26, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
I got kenmore 70 series. it doesnot spin but it
You have a bad lid switch . This is the piece , the lid actuator piece , goes down onto , in the hole on the top . Try putting a screwdriver into the hole , to activate the switch , to drain the water and to spin the clothes dry enough to remove , until the switch can be replaced .
Nov 26, 2009 | Kenmore Washing Machines
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore 70 series
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24932 Top Load Washer Logo
146 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
