Question about Celestron StarHopper 10 Telescope
Where to find the gearbox for the 1994 celetron dec motor gearbox
    Genius:
  • 1,027 Answers
Starhopper does not have a gearbox - strictly manual.
Posted on Jul 10, 2008
My 4x4 does not work, the light does not come on, the lights dim slightly when you push the button. Any suggestions?
4x4 Troubleshooting guide - Ford Explorer and Ranger Forums ...
www.explorerforum.com > ... > Stock 1991 - 1994 Explorers
Dec 16, 2007 - 19 posts - ‎12 authors
4x4 Troubleshooting guide Stock 1991 - 1994 Explorers. ... Interactive How Cars workAnimation. ... As such when returning to the 2H position the shift motor doesn't stop ...vehicle is not in 4x4 unless both the dash and button lights come on. ... John D-"Search first, Ask questions later" & "You can have my ... Headlights won't work :(
Aug 9, 2015
No injector pulse, no EEC-IV Diagnostics
Dec 9, 2007
'94 Push Button 4X4 not working
Dec 7, 2007
More results from www.explorerforum.com
Nov 19, 2015 | 1988 Ford Bronco
I put a new motor in a 1991 jeep comanche new dis and new coil and it backfires what can it be it is on number 1 top dec center
your timing is out ask a local mechanic to check it out for you ,maybe even the firing order
Apr 14, 2012 | 1994 Jeep Cherokee
1994 Buick Century - drivers electric window goes down but stops on way back up - if you wait a minute and try to close again goes up a little more and quits - wait another minute and try again goes up...
You either have a bad motor(regulator) or bad bushings in the motor gearbox. If you do not want to open the gear box, then replace the motor/regulator assembly(bushings already installed) which is what most people do.
Please take a moment and rate my answer.............. Thanks
Dec 01, 2010 | 1994 Buick Century
Where would i find the starter motor on bmw 316i 1994 -1998 please
For BMW 316i 1994 - 1998 you will find the starter motor on the right part of the car at the bottom back right side of the engine, between clutch case (or automatic gearbox case) and cylinder block.
Jan 28, 2010 | 1994 BMW 3 Series
How do i replace the gearbox of a holden VR?
Taking out the tail shaft from the rear diff but before pulling out of the gearbox Drain the oil from the box,take out the shaft,Take off the battery earth lead,and now the starter motor.and the bottom metal plate at the bottom of the bellhousing (should be 4 small screws. and undo the 4 bolts on the flywheel metal plate which hold the torque converter on to engine. undo the bellhousing bolts and the top hose on the radiator ,and the gearbox X member and let down g/box slowley and slide it off WITH converter on the box ,
When refitting the other box its all in the reverse of removal (ALL OF IT) as well as the converter on the gearbox before it goes in as it fits on the shaft and turn it around and keep going untill it slips into the 2nd lot of splines and in line with the bell housing face.(Do not damage the g/box seal).
Let me know how you get on , Aussie Ron
Nov 23, 2009 | 1994 Honda Accord
Holden barina 1994 manual gearbox linkage problem
had the same sorta problem with my one, i replaced the las part of the linkages thats connecte to the gearbox, that helped with it. also check to see if the blots holding ur gear stick in place are tight
Sep 01, 2009 | 1994 Honda Civic
Loose vacuum line
That is probably just a vent hose for your gearbox or front differential. It doesn't need to be connected anywhere other than the gearbox.
Dec 27, 2008 | 1994 Jeep Grand Cherokee
The automatic gear have a delay in changing the speed number four in model 94 VR6
Maybe a stupid suggestion, but check the oil amount in the gearbox. It must be done with the motor running. I did´nt know that and checked it motor off when the level on the dipstick was fine. When I checked it motor running it was too low. I filled it up and the gearbox works fine...
Aug 30, 2008 | 1994 Volkswagen Corrado
Mazda 323 1994
most late mazdas have 4 mounts 1 on right side of engine at the top.1 on the left side at bottom where gearbox and motor bolt together.1 on the back lower part of engine (on gearbox).the last is on top of gearbox under the battery tray.
Jun 15, 2008 | 1994 Mazda 323
Celestron StarHopper 10 Telescope Logo
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Are you a Celestron Optic Expert? Answer questions, earn points and help others
