Question about Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher
When SHE43M05UC is finished with any wash cycle, there is about an 1 1/5 inches of water left in the bottom of the tub. It will not completely drain. I followed instructions as per Care and Maintenance section removing and cleaning filter system and large object trap/cylinder filter assemblies. However, the problem has not gone away. Varick Dawson
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
  • 27 Answers
SOURCE: i have a bosch dishwasher classixx its less than a
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Posted on Mar 12, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher model SHV6803UC/12 - washing
Welcome to FixYa.
I`ll start by letting you know there are many things which can manifest in the manner you`re describing...or even how one interprets what you`re describing.
Having said that are you referring to water in the tub or in fact the "pan" also known as overfill basin ?
**before performing any repairs please turn off the power to the dishwasher...safety first**
In either case I would instruct you to start by checking the drain hose where it is connecting to your home plumbing...i.e. under sink or into food disposer/garberator. for kinks or obstructions.
Also remove the filter assembly and check for food or soap deposits clogging the sump assembly.
**ultimately it may in fact be a faulty drain pump not pumping the adequate volume of water for the time allowed...but I certainly would check the drain first**
That is by far and away the most common cause behind the problem you are describing...based on my understanding as I mentioned.
Let me know if indeed this was helpful or not and we can move forward from here.
Either way thank you for choosing FixYa today. I`ll watch for your reply.
Regards,
Macmarkus :)
Posted on Sep 22, 2010
  • 330 Answers
SOURCE: Have SHU43C and have had no problems with it. We
the drain pump needs to be replaced or cleared of obstruction.
Posted on Jan 12, 2011
  • 180 Answers
SOURCE: Bosch Integra SHU 9955US/12 -
Sounds like your motor is burned out. The drain motor and wash motor are seperate on your machine. You can check for power going to the motor, but to do this you might have to pull the dishwasher out. While the cycle is running check for 120 VAC going into the motor. If you are getting power and nothing is happening, you will need to replace the motor, otherwise you will need to replace the motor control board located at the base of the machine.
Posted on Jan 31, 2011
Dishwasher won't drain completely
perhaps it need that air gap device added .we call it a siphon break here .
Sep 06, 2015 | Bosch Dishwashers
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher Logo
50 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
