I got the steps out of sequence installing the device. I told it to install before I had the router ready. The device config would not allow me to reset the connections, so I tried to remove/reinstall. It wouldn't let me do that so I tried to delete the files one at a time, but it got down to the .exe and utility files and would not allow me to do anything to them so now I'm stuck.
  • 4,338 Answers
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 02, 2011
I have forgotten my passwork to my wireless cisco linksys E3000, how do I go about retrieving it?
he WEP key is defined by the person who set your wireless router up. You will not be able to find out what the WEP key is, but you CAN change it if you have physical access to the router. If you are trying to connect to your wireless router and can't remember the WEP, then walk over to the router and on the back or bottom of it is a small little hole that you can fit a pen or paper clip into. Press the paper clip into the little hole for 10 seconds and release. This will reset all the settings on your router back to default and will allow you to access your wireless connection.
Note: doing this will take away all of your wireless security so make sure that you know what you're doing before messing with it!
Thanks and please rate if this helps you at all :).
Mar 29, 2011 | Cisco Linksys Refurbished E3000...
My printer is not connecting wireless from my comp. I brought it over from my parents house to my new place and it wont work.
For installing a wireless printer on Windows XP, wireless router is an essential device.
Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network.
Since several computers or laptops will access the printer, it is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
Jan 06, 2011 | Office Equipment & Supplies
How do I install my Dell P703w wireless printer on my network without the installation disk
For installing a wireless printer on Windows XP, wireless router is an essential device. Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network. Since several computers or laptops will access the printer, it is recommended to connect the wireless printer to the main computer through the USB port. To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting. This will allow the operating system to recognize the availability of a wireless printer. Now, click the Start button, go to Devices and Printers, select Add a Printer option. Click the second option- Add a network, wireless or Bluetooth printer. The computer will search for available printer and reflect it on the screen. Click Finish; and the printer is ready to begin the printing process.
Dec 23, 2010 | Dell P703w Printer
Hi i have 1841 router what is the default user name password for this i tryed with user name passowrd as cisco but is saying that no user cisco pls help me
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Jul 02, 2010 | Cisco (1841) Router (cisco1841)
Install router on windows XP
you could download the quick start from linksys.com for that but basically there is no installation necessary with windows, it's a network device that does not need to be installed. simply plug it in.
Jun 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Opening routers config page.
Most router config pages can be opened at http://192.168.0.1 or http://192.168.1.1 . Better confirmation can be made if you provide the router model. You can also double check the address by going to start > run, typing cmd then hitting enter. In the command window that pops up, type ipconfig /all and press enter again. In the information it returns, you will see a Default Gateway address. That address should lead to your router if you put it in your browser.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Wireless Printer Setup
Since several computers or laptops will access the printer, it0 1is recommended to connect the wireless printer to the main computer through the USB port.
Feb 15, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
