Question about Honeywell Heating & Cooling
Heater power is on but no fan, no heat and caution light comes on when i turn the thermostat up.
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMPB-75-4 Rev 13
Is there a diagnostic chart either on the reverse side of the blower door or in your owners manual. It may help you to narrow down what is going wrong.
Operate the furnace with the access door off of the furnace and the blower door switch taped on. Watch the furnace and document what happens. Note if the flame starts but goes out in a few seconds and let me know what you experienced.
Posted on Nov 17, 2007
SOURCE: CAUTION LIGHT only -- no Fan or Heat
According to the manual, the "Caution Light" means that the unit has overheated. They suggest running on a lesser setting, but you also may want to see if you can return the unit (if it is still under warranty).
Posted on Jan 01, 2008
SOURCE: Lasko 5610 red caution light, no power
In the bottom of th e 5610 there are 2 automatic reset breakers. In betwene the two there is wire connecting them together. In the middle of this wire is a thermal resister and thats what repaired mine. Replace it and your heater will heat again.
Posted on Mar 06, 2008
SOURCE: Duracraft Heat Giant Electric Heater Model CZ-2104
since it's old and dust soaked, i'd replace it with one from walmart at about 30 bones.
it's safer to not try to revive it cause it's old and stressed out and has had juice running through it's poor, old wires for way too long.
i wouldn't take the chance on repairing it.  those are just the types of details you don't hear when someone burns to death via a faulty space heater.
Posted on Apr 06, 2008
SOURCE: lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Posted on Nov 10, 2008
Heater won't start. put new batteries in thermostat and the fuse is good because when I pull it out the slow flashing green light on the electronics board goes out. I raised the maximum temp on the...
Shut off power, disconnect thermostat wires from control board. Put a jumper wire between R and W turn power back on. If the garage heater starts and heats, your issue is in the thermostat. If it does not start or heat, your problem is in the power coming.
Check power coming in, it should be 110-120V if you have it there, check to see if it has a transformer, if it does check for 24v on the secondary side of transformer, if you don't have it there, replace transformer.
Oct 23, 2013 | Cayenne 60,000 BTU Residential Gas Furnace
The heat will not turn on
If the fan is blowing with no heat, it is an indication you have an error code. Check the control board for a blinking light. If you find one, look on the wiring diagram that is pasted on the reverse side of one of the panels for a diagnostic chart. It will give you a starting point where to look for the issue. You can always jump the red and white wires on the thermostat and if the furnace starts, it's a bad thermostat. If not, look to the blinking light.
Mar 07, 2010 | Honeywell Electronic Programmable...
My heater won't turn on. It is the first time we tried to use it since I installed the thermostat a few months ago. My husband turned the mode to heat and the fan to on. However, only cold air is coming...
you need to bypass the thermostat wire it jumper wires. in other words jump the wires till the furnace comes on. there are 18 volts at the thermostst. listen for it to click. and set fan to [auto] always
Dec 05, 2009 | Honeywell Programmable Thermostat Heater
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Nov 24, 2008 | Honeywell Programmable Thermostat Heater
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Lasko heater model 5620
Feb 12, 2008 | Heating & Cooling
I have the same heater,04-08-97, have had problems with fan motor bearings, does the heater,Humm, when turn it on, this indicates loose motor bearing fan side.If so,unless you can find a replacement motor,as I have tried,your heater is on the way to the scrap yard.If you can find a replacement motor, please post it.
Jan 16, 2008 | Heating & Cooling
Smeg single fan oven
You are right, it could be a thermostat or a heater problem. You should check that the heater element receive power. In case it receive power,the heater element should be replaced. In case it doesn't receive power, the problem is with the thermostat. In any case, check as well that all wires connected to the thermostat and the heater are in place. Good luck.
May 02, 2006 | Smeg SE250XUK Stainless Steel Electric...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
