Question about PfaFF Sewing Machines
How to thread pfaff 1200 grand quilter - PfaFF Sewing Machines
bargainbox
  • 1388 Answers
SOURCE: I have purchased a Pfaff 18.8 Grand Quilter
Speak to the Pfaff dealer where you bought it and tell them....they will probably arrange a replacement with little fuss.
Posted on Aug 27, 2009
Testimonial: "Thanks for your prompt response: Both I and my dealers have been working together No luck but thanks for trying"
SOURCE: can not get thread tension on hobby 1200 grand
Adjusted the dial to the right until the stitches we better.
Posted on Dec 27, 2009
SOURCE: Pfaff grand quilter 18.8 with Q-Bot, and having
the up and down buttons are not working properly. When pressing the needle down button, the needle does go down and then comes right back up. pressing the needle up button makes the needle shoot up and down 2 times very fast. HELP
Posted on Apr 21, 2010
  • 22 Answers
SOURCE: Grand quilter 1200 I had to replace a needle the
: unthread the machine, take a brand new size80 needle and install as shown in your book(scarf of the needle to the right hand side) very important.. Now reomove the bobbin case and double check the threading of it, reinstall the case . now rethread the upper thread. Place a sample material under the foot , turn the handwheel in direction of rotation for a few turns. If the machine appears to be making a stitch , u can use the foot control to test to see if the machine is now working
Posted on May 03, 2010
  • 1456 Answers
SOURCE: I have a Pfaff grand Quilter and my top thread is
Hello
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Posted on Jul 15, 2011
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
What are the correct thread tension numbers on thePfaff hobby grand quilter 1200
Usually, the standard tension for upper thread is midway between high & low numbers. However, every machine differs and may need to be tweaked. Unfortunately, finding the correct tension is generally a test and adjust method. Be sure you are using a brand new needle and good quality thread.
Oct 10, 2016 | PfaFF Sewing Machines
How do I raise and lower the feed Dogs on the PFAFF hobby 1200 Grand quilter
According to the following web site, the feed dogs do not drop on this machine, Instead, there is a plate that covers the feed dogs:
Fluffy Sheep Quilting Do you have one of these Do you like it
Also thought this was interesting:
Oiling the PFAFF Grand Quilter 1200 Bernina Sewing Center Tampa
Dec 10, 2015 | PfaFF Sewing Machines
How to thread a pfaff 1200 grand quilter sewing machine
contact Pfaff website about a manual or try youtube for a video
Aug 25, 2014 | PfaFF Sewing Machines
Thread has wrapped around in behind the cb hook system and I can't figure out how to get if off to clear the thread. There is so much thread that I can't even move the needle up or down, it is jammed. Is...
If you can open the machine cover you may be able to get access to the hook. That should allow you to remove the thread without having to remove the hook.
Mar 27, 2011 | PfaFF Sewing Machines
Sewing Machines Logo
219 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
