Question about KitchenAid Microwave Convection Oven
We have a KitchenAid built in MicroWave. The Model # is YKHMS1850SS-0. The top front SS/Plastic Vent piece that mounts above the Door in front of the Vent Fan has the plastic screw brackets broken and the piece has fallen off. Can the piece be replaced? If so price & delivery time to receive once ordered. Thanks.Peter
  • 731 Answers
I cannot determine from your description what part it is you exactly need.
This is a link to Sears Parts and you make and model
Look through the diagrams.
As for price and delivery... that's up to Sears
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-YKHMS1850SS0/0593/0123370?searchedModel=YKHMS1850SS&blt=
Posted on Jan 02, 2011
Frigidaire Microwave will not run unless door latch is pushed in half way.
There are usually 3 door interlock switches on most microwave ovens, which are held in place by plastic pieces which are screwed in place from the front of the microwave oven (although you may have to remove or tilt out the top of the control console to see them). Make sure these plastic support pieces are positioned against the front of the microwave oven, and make sure the screws are tight.
Sep 17, 2014 | Frigidaire Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Kitchenaid Microwave Oven model Kcms1555rss stuck on same cooking time. There is a line with 3 other lines also on the screen
Hello :
It could be a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
Warning : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Rattling coming from top grill on Kitchenaid microwave
the gril at the top (above the door) usually comes off with a couple of screws or just pulls off .. on some you have to take the cabinet apart ..... inside you might find a flat filter put in at a slant .. its often a grease and smell filter that contains activated charcoal .. when it gets clogged then it can rattle around as air tries to get around it .. you can replace it or just leave it out ..
Oct 04, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Over the Range Kitchen-Aide Microwave/Vent Stainless Steel
You'll need to provide the specific model number in order to get the part you need but here is a link to a company that should be able to get you what you need.. http://www.pcappliancerepair.com/whirlpool-parts.shtml
Hope this helps..
Sep 14, 2008 | KitchenAid Microwave Ovens
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
KitchenAid Microwave Convection Oven Logo
138 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
