Question about HP LaserJet 1020 Printer
Can I print on anything aside from regular copy paper. ie, thin, parchment like paper? I am trying to copy a very old, thin letter my Dad wrote to my Mom and to make it look authentic I would like to find very thin paper to replicate the original.
    Sergeant:
    Champion:
  • 342 Answers
Yes you can all you have to do is use the manual paper tray that is usually on the front wher you would put other papar like envelopes and other materials
Posted on Jan 02, 2011
When typing on carbonized paper, doesn't seem to be striking hard enough. When typing on regular paper, print is fine
I suppose you are using carbonized paper to obtain 2 copies... Then probably the first sheet of paper you are using (the one over the carbon paper) is too thick. I remember that when one wanted to make copies, it was important to use thin paper or the copy (the page under the carbonized paper) would appear too pale. Try with a thinner paper, especially as the paper used in printers and photocopiers is stronger than the one that was produced for typewriters.
Apr 28, 2016 | Swintec Refurb 1146 Cmp Typewriter...
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
How increase decrease paper size when copy on hp m1005
The paper size setting are in the print menu. Fairly similar on mac and PC. When you try to print stuff you will see a window with options for the print (colour, copies, etc...) in that menu there is a paper size section. Most printers dont take anything wider then US letter but you can do longer (just put it in the slot) or slimmer buy pushing the plastic paper handlers in on either side of the paper bay.
Oct 18, 2012 | HP LaserJet M1005 Printer
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
How can you configure Zebra printer 105sl (over network) to print labels in IE and have a regular printer from reducing the document size from a thin client?
I have this issue whenever I set my default printer to a label printer. Use the other printer as the default and set to the zebra only when you need it.
Dec 07, 2011 | Zebra 105SL Thermal Label Printer
Just replaced ink and is barley printing regular letter
Your print head needs replacing:
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Contact Kodak for a replacement:
Live phone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight Eastern time, 7 days a week.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Feb 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
