Question about Microwave Ovens
Light in oven is out-can I change bulb and how?
  • Microwave Ovens Master
  • 9,047 Answers
The owner's manual will cover that if it's a user-changeable type.
You can download GE owner's manuals and installation instructions here.
If yours is a different brand, post a new help request to FixYa and include your brand and full model number.
At our Web site, we have a video available showing how to remove a typical over the range grille in under 5 minutes.
If it's not user-changeable, or if you need other parts or accessories, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
For other brands, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 02, 2011
How do I change the light bulb?
It is hard task.
  • You will need special tools, e.g. Torx screwdriver (star) and other
  • Be careful. Oven must be disconnected from mains.
  • The disassembling is complicated and procedure consist of more steps.
  • Microwave oven lamps bulbs are very special. They often do not have usual lamp cap. See Microwave Oven Lamp Bulb with Base
  • Watch this video as example what will your task:
Microwave Oven Lamp Replacement Samsung T170 Light Bulb UK
Some oven lamp types:
Home Office Light Bulbs Microwave Bulbs
Jan 28, 2016 | Microwave Ovens
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
Need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
Jul 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
HOW TO CHALGE LIGHT BULB
disconnect the oven from power supply. If the lamp of your microwave is in the most common location, you will need to open the oven by unscrewing the screws on the rear. You will see the lamp behind the control panel. remove and replace the bulb
Jan 12, 2010 | Goldstar MA-1011 Microwave Oven
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
