Question about Frigidaire Kitchen Ranges
My FGFLMC55ECA 5 burner gas stove with double oven is beeping without error code. I turned off the breaker, back on 2 minutes later, it continued to beep. Thoughts?
catriver
  • 878 Answers
SOURCE: F1 and constant beeping
Tul2pi, there are several things that could cause this. 1. shorted keypad. If you unplug the keypad ribbon from the board and the beeping stops it's more than likley your problem. 2. Temperature probe in the oven may have gone bad. You would have to ohm this out. At 75 degrees it should read approx. 1091 ohms. 3. Worst of all it would be a control problem itself where as you would have to replace the control board. Since you are so close to the warranty period, I would call Frigidaire at 1800-944-9044 and see if they would cover it...Catriver..post back.
Posted on Aug 29, 2006
  • 110 Answers
SOURCE: EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Posted on Jun 01, 2008
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
SOURCE: My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Posted on Nov 18, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
How do I fix my stove? None of the radiant elements are working.
Have you confirmed that you do have 220 volts at the range outlet? If you don't, turn your breaker off then on and recheck the voltage with a meter. Any losses of voltage through the breaker indicates you may have a bad breaker. (Do this with the stove unplugged from the stove power receptacle). Next, have you pulled one of the elements off the stove and checked it with an ohm meter to see if you have continuity. No continuity indicates the element circuit is incomplete and the element needs to be replaced (you should have a reading on the ohm meter if the element is good).
Dec 30, 2014 | Samsung Electric Convection Range...
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
91 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
