Http:// I posted the photos you requesed at
  • 1,139 Answers
I just sent a reply, There should be an access point to the drive motor that will allow you to turn it and then this will release the carriage lock and lift the carriage so that you can remove the tape.
Posted on Jul 09, 2008
Carriage jam- open door clear carriage jam and then press ok
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 18, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How too change ink
Follow these procedures to help you get access the cartridge. This is taken from the online manual of Fixya.
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
Close the print-carriage access door.
Please rate this answer. Thanks for using Fixya.
Aug 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Jun 15, 2010 | Epson Stylus Photo 1200 InkJet Printer
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
During startup the drive belt slips and gives an error
Open the printer's door and look for the print carriage. It's the platform that moves back and forth over the paper, probably where you put new cartridges. Unplug the printer, and check this belt and its pulleys to see if it's either broken or possibly covered in ink. The drive belt will be black and have gear teeth on it. If you see a metal or plastic ribbon, that's more likely the encoder that let's the printer's computer read the position of the carriage. See if you can nudge the carriage and make it move a little; it may simply be jammed. Check the carriage's moving path and make sure it's not obstructed. Any other problems would probably best be handled by Epson.
Feb 27, 2010 | Epson Stylus R380 InkJet Photo Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Problems with circuitry on my trc-931 boombox Don't click: link
Oct 27, 2008 | Lasonic TRC-931 Cassette Boombox
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Can't move cassette carriage.
hello savvychris
If you can not get to the carriage motor, can you get to the one of the gears attached to the motor or the carriage gear itself. either of these should allow you to release the carriage.
Can you post some pictures of the carriage, this includes front, top, and side shots? what I am looking for is a way to advance the main motor forwards and thus release the carriage locking system.
If possible, if you have the technical documentation, send me a copy of it, I might be able to figure out what is going on for them.
Thank you,
Jul 05, 2008 | Televison & Video
Epson 1280 Solid red mainteance light
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
Televison & Video Logo
Top Televison & Video Experts
