My Acer Aspire One D250 is stuck on the Windows XP loading screen. I have tried unplugging it and plugging it back in again, and have even taken out the battery and just plugged the power cord into it. I've also tried going into safe mode and it gets stuck on the welcome screen. This model has NO CD-DRIVE. I've had this laptop for about 10 months and have had no problems until now. There was a lightning storm the night before this happened and it was on and plugged in. What should I do?
  • 335 Answers
Hi Mimi,
If you can live with losing all the data on the netbook, you can reset it to factory original by pressing and holding alt + f10 right after you power it on. This will trigger the Acer e-recovery management utility which will allow you to reset it. If you do this, you will lose all data on the pc. If this is a problem, you may have to take it to a service shop to have your data backed up first. Also, if you can't get the alt+f10 thing to work, you can take it to an Acer authorized service centre and they can send it to Acer for warranty repair as it is less than 1 year old. Acer normally does not cover software issues, but if alt+f10 doesn't work, it could be an issue they will cover under warranty.
Hope this helps!
Regards,
Joe
Posted on Jan 02, 2011
Help! My Laptop Acer Aspire One stuck at window logo loading Anyone please, help my acer aspire one stuck at window xp logo loading. I try everthing in F8 button, it didn't work, even in safe mod
oh a fun one. Reset your bios to defaults. if that doesn't work then try a windows disk boot up. if that doesn't work you're screwed.
if you want any of your files from the computer first pull out the hdd buy a cord and transfer them to another computer.
Sep 07, 2012 | Acer Aspire One PC Notebook
Acer aspire D250 bluetooth driver
Drivers for Aspire One D250 @ http://support.acer-euro.com/drivers/notebook/as_one_D250.html
Under "Drivers and Utilities" MS Windows XP -> Select your needed drivers.
Hope it helps.
Mar 28, 2011 | Computers & Internet
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
My acer aspire one d250 wireless adapter is not available or not connect after I format my laptop because it had a virus in which I was not able to use the recovery disk on the d drive. I installed window...
I had same problems before on installing Windows Xp service pack 3 that some component of your computer is not working well webcam not working and others. I believe that the hardware components of the service pack 3. Try to install other operating system like service pack 2 and upgrade for SP3 is available or other.
Dec 22, 2010 | Acer Aspire One PC Notebook
My acer aspire one is stuck on the xp loading screen???????
will it boot into safe mode (F8 on boot)
if it will, you may be able to run disc tools to check for problems right click on your c: drive / tools.
If not. you may need a copy of windows to run a repair installation.
Please write back if you cant boot into safe mode
Aug 09, 2010 | Computers & Internet
My Acer Aspire one D250-1938 shows a blank screen only. Maybe it somehow stuck in hibernation mode. Have forced shutdown and restarted, tried F5, F6, F7, but still no screen. Any suggestions?
Try remove the battery, let it for 30 minutes without it, then plug it again the battery, then turn it on.
If still won't work, remove again the battery, wait till 30 minutes, the plug the charger, don't use the battery yet, then turn it on.If it works, you can plug in the battery again.
Feb 26, 2010 | Acer Aspire One PC Notebook
My Acer aspire one can't seem to get past the windows xp loading screen without glitching and starting up again and then telling me it had a problem and to try starting it up these 5 different ways. Even...
that can be an issue with windows. try to press f8 upon start up. you will enter the advanced boot options menu. select last known good configuration and hit enter. check if system will now load windows. if it still doesnt, go back to advanced boot options and select safe mode. it it does load safe mode, run system restore. if not, you will need to reinstall windows. hope it'll help. good day. =)
Dec 03, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
