Question about Air Hogs Havoc Heli Helicopters
Charger won't stay in heli...green light won't stay on to indicate charging is occurring
I had the same problem after not using that for one year. I guess the cell is dead. Time to change the rechargible battery? If any one know the trick, please send me an e-mail to: xy_zhu2001@yahoo.com. Thanks.
Posted on Jan 03, 2011
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
Found a previously posted solution here:
http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
SO33G charger over heat ,
It is no use to buy a new charger if the problem is a short. Indications are that it is. When the batteries are in need of replacement and wont charge up, overheating of the charger will also occur.
Jan 03, 2018 | SYMA Toys industrial Toys
How to charge a makita battery
remove the battery from drill and insert into the charger, the red charge light should come on and then after about an hour it should change to green indicating a full charge, there is a lable on the charger to indicate other problems that might occur. Let me know if you need more assistance.
Jan 08, 2012 | Makita Drills
Just bought an S107G. I have brand new batteries in the controller, and the heli is fully charged. The light on this controller when turned on is solid red at all times (should be green right?) The...
Do the lights on the heli come on?
Normal start-up would be:
Turn helicopter on. Flashing light in nose should come on, as well as another blinking light (sometimes towards the rear, sometimes in the "cockpit" area) the helicopter MUST then be placed on a level stable surface until the 'other' light stops blinking, usually a couple/few seconds. This is the gyroscopes synching up and determining the "level" head orientation they will be maintaining. Then power the controller on. Making sure you're not covering the front of the controller with your hands, (the IR signals come out the front like a TV remote) push the throttle control (left joystick) up until the blades move. This what the horribly translated instructions mean by setting the helicopter and controller together.
Don't charge with the controller. It kills your controller's batteries, (which will last nearly forever if you don't use them as your heli's charger) and seems to make the birds act weird. Use the USB charger and a fully powered USB port (back of your desktop, not the front) and go by the light on the charger not an arbitrary time. Plug in charger NOT connected to heli. Look at the light. That is what the light will look like when unit is fully charged. Make sure heli is off. Plug into charger. Charge until light is fully on. If you unplug heli and the light gets brighter, it's not charged fully. A weak USB port (on a laptop or the front side data port on most desktops) may take several hours to achieve full charge. Always cool 10 mins after charging AND 10 mins after flying. Never drain fully, it will kill the Li/Po battery. Land and power off as soon as you can't maintain altitude.
If it is really charged, and you turn it on and nothing happens... no lights nothing. Then it's defective/toast. Return for refund.
These SYMA helis are awesome, and HANDS DOWN the best on the market... but they can be picky/tricky on how they are treated.
Please let me know if this helps.
PvT
Jul 27, 2011 | SYMA Toys industrial New Syma S107 Mini...
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Dec 26, 2008 | Air Hogs Havoc Heli Helicopters
Air Hogs Havoc Heli Helicopters Logo
422 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
