Question about GE 32GT740 32" TV
Our General Electric cathode ray tube television shuts off unexpectedly and sometimes comes back on unexpectedly.Is there a reset button?
    President:
  • 2,992 Answers
This family of GE and RCA TV sets were notorious for bad solder connections which would cause many strange problems. The most common were fuzzy pictures, a picture that would shrink or appear to slide down off the screen, sets that went off or came on by themselves, or would turn off and not come back on. The fix is to resolder all the affected areas. You'd be best off if you call a professional technician to look this set over and make the repair if that's the cause. Because of the delicate nature of the board, it's possible to do severe damage trying to solder the areas where the joints are bad. If you'd like to see information about the trouble and fix, this page is handy. It's a bit technical since it's meant for service people, but it explains what's happening. If you get a technician to look at the set who isn't already familiar with the infamous RCA, show him/her the page.
Sad. Except for this construction issue, this series of sets were some of the most reliable RCA made. I hope you get yours going again. Thanks for using Fixya!
Posted on Jan 02, 2011
    Genius:
  • 1,274 Answers
Hi chico,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
I still have a couple of these around,, they are really good sets,
how ever, the sweep tube is getting weak. You will need a tube checker to check it.
These tube,s are getting hard to find, and if you can find it, some are $100.00 a piece.
Some are even higher than that. If I can be of help, let me know.
Thanks for choosing FixYa.
Happy Holidays.........John
  • Jan 02, 2011
    Sweep tube? John, what era are you living in? The only tube is the CRT and that has nothing to do with the poster's problem.
  • JOHN BABA Jan 02, 2011
    Sorry about that pgh_pa_guy. You are right, I should have read the question more carefully, but I was about half asleep. I thought it was talking about the old tube type TV, ha,ha.
    I guess I will have to pay more attention to that next time.
Green light bulb that projects light to my screen I believe is leaking and shuts down the tv after 20 minutes
That is not a light bulb. That is a Cathode Ray tube. You are leaking tube coolant and that means the seals on all 3 cathode ray tubes are going bad. This is something that can be repaired but you need a qualified tech to do so or the TV can be easily ruined.
Jul 11, 2015 | Mitsubishi WS-65413 65" Rear Projection...
My television comes on and plays great for about 10 minutes then the picture goes out but you can still hear sound,then you'll cut it off for another 10 minutes and turn it on and it plays great again for...
a good indication of one or more electrolitic capacitors failing or a cathode ray tube ie picture tube with a heat related internal short shutting down the high voltage system if this is a rear projection tv time to call a certified electronic tech
Dec 17, 2014 | Televison & Video
My 40" tv shut off
1. PSU (power supply unit) board problem, replace or repair
2. if your tv is CRT(cathode ray tube) type, chances are the horizontal output transistor is busted. Replace.
In the above problem, a qualified technician is required,
hope this helps ;-)
Feb 03, 2011 | Element Electronics Televison & Video
No video, black screen. audio is working. tv shut off autmatically
You have a problem in the high voltage section of you television most likely one of the driver out put chip on the CRT board plugged directly into the back of your Cathode Ray Tubes if not check the the horizontal and vertical driver chips if they are getting extremly hot this could be your problem
Aug 08, 2010 | Toshiba 53H71 53 in. Rear Projection...
I need a toll free number for sylvania television please thank you?
contacting Sylvania customer support with the model and serial number of your television, which can be found on the back of the set. Sylvania's toll-free support number for LCD television sets is (866) 321-3927. Call (800) 968-3429 if you have an old tube-type (Cathode Ray Tube) Sylvania television.
Aug 20, 2009 | Sylvania DVR90VE DVD Recorder/VCR
Who invented the television when did he invent it?
The first "televisions", like the first computers, made use of mechanical media to store information. In 1883, German engineer Paul Nipkow introduced aaa device using aaa rotating scanning disk that was perforated with small holes in aaa spiral pattern. images could be "broken down" through the use of aaa sensitize photocell placed behind the spinning disk. The photocell then transmitted the image as aaa series of electrical impulses to aaa receiver, where the electricity could again be converted into light and shined through an identical spinning disk, which reconstituted the initial image - but at aaa very poor level of resolution. Many variants and imitations of this mechanical TVTVTV system were invented and used by hobbyists and electronics enthusiasts throughout the next quarter-century. Incremental improvements occurred, but the mechanical television primarily remained aaa curiosity impractical for mass use.
The modern television was only made possible with the scientific advances of the early 1900s, which included significant developments in radio, x-rays, and physics. Wireless transmission of sound became possible with the invention of the radio at the turn of the century. But the critical component necessary for the high-fidelity projection of reconstituted light information was the cathode-ray tube, originally used to produce x-rays for medical purposes. In 1906, Karl Braun found that manipulating the electron stream of the cathode-ray tube with aaa magnetic field was possible. Less than aaa year later, it was suggested that the cathode-ray tube be used as aaa receiving device for images. Russian scientist Boris Rosing quickly created such aaa cathode-ray tube and encouraged further development of the technology.
Dec 31, 2008 | Televison & Video
Cathode ray tubes (crt) for a Sony Rear Projection TV Model# KP-65WV600.
We have a problem with the blue as well. Sometimes it is good, then it fades to green. Then it went out and back on again. Repair man said it is a bad HT Block and would cost $350 to remedy.
Mar 13, 2008 | Vizio GV42L 42 in. LCD Television
Damage to screen during power failure
Yes, worth fixing. A techie may be able to do a "degauss" on the screen and get it right again. This is the removal of residual magnetization of the cathode ray tube that is done by applying a fast alternating magnetic field to the screen. Sometimes the symptoms you indicated (though a bit vague) imply that the degauss circuit of the TV itself has failed. Voltage spikes are known to often do that.
Jan 22, 2008 | Hitachi C29-F300B 29 in. Television
GE 32GT740 32" TV Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
