Question about OmniMount 23" to 42" Fixed Flat Panel Mount
Hi I have the OMNI Mount U3TILTMOUNT universal display wall mounting system, i need one part which fixes the TV to wall. I do not need the entire wall mounting kit. thanks som
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
No screws to mount AKAI LCT3701AD LCD TV.
Hi i bought mine at home depot for a few dollars they were very helpfull there and they worked great...
Feb 03, 2010 | Akai LCT3701AD 37 in. LCD Television
Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
Nov 13, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Wall Mounting
I purchased my tv mount from Ultimate Electronics/ Las Vegas, NV. The name of company is Omni Mount, model: U2 Fixed. The phone number is 1-800-MOUNT IT. Good Luck.
Mar 12, 2008 | Protron PLTV-32 Television
Bracket for tv
use shelve brackets, I did and they worked fine
Jan 18, 2008 | Akai LCT2715 27 in. LCD Television
Samsung 101cm lcd Mounting??
Yes they are the mounting holes but I would not trust a universal mount to hold an expensive TV set on a wall.
Nov 26, 2007 | Televison & Video
Wall mount doesn't fit holes on tv
As your learning a universal wall mount won't work on this set because of the hole configuration, below is a link to one that should work but its not cheap.
AW51 NEW AKAI PDP TELEVISION WALL MOUNT BRACKET PMT4290 NIB AW51 eBay
Feb 23, 2018 | Televison & Video
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
OmniMount 23" to 42" Fixed Flat Panel Mount Logo
69 people viewed this question
Top OmniMount Televison & Video Experts
Are you an OmniMount Televison and Video Expert? Answer questions, earn points and help others
