Question about Intel D845GVSR Motherboard
My processor is loose thats why pc hangs often! what to do?
    Sergeant:
  • 223 Answers
Your PC get hang offen mean your memory is not sufficient to your processor to process to try to upgrade your memory , or else you have have virus in your system so that it high your cpu process so that too your PC get hanged. check your cpu speed by clicking ALT + CTRl + DELETE at same time, and check which program utilizing CPU more
Posted on Jan 02, 2011
Second socket hangs board
I know there is a setting in the BIOS for enabling the second CPU socket. Is that enabled?
Jan 09, 2010 | ASUS Computers & Internet
I have Dell GX280 system. My Fan produces more sounds and runs fast. System Hangs while processing and performs slow, causes processor nore hot. I pasted the Heat Sink Paste on processor that resuls in low...
More than likely your fan needs to be replaced. These small form factor Dells are know for problems like this. Warning! Do NOT attempt to blow out the CPU fan with canned air, as this will likely lodge dust particles in the axis of the fan causing it to drag and become louder!
Sep 09, 2009 | Dell OptiPlex GX280 PC Desktop
System hangs up frequently
Might be a loose RAM (memory stick). Try removing it and then connect it again properly and see if it solves the Problem.
Jul 12, 2009 | Intel Pentium Dual-core Processor E5200...
Computer hangs during xp installation
make sure you have met the minimum hardware requierments when installing your XP...which is
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Apr 11, 2009 | Microsoft Windows XP Professional for PC
Keyboard and mouse problem
1. You can disconnect the Hard disk then test the system if keybaord and mouse working, then there i s problem with your operating system or RAM.
2. Processor fan will rotate even after system hang up.
3. Check the RAM for cause
4. Operating may need to reinstall
May 25, 2008 | Intel D101GGC Motherboard
Laptop startup problem
If it has been banged around at all it's possible that the MB could be cracked. You could check the bottom screws to make sure they are tight as they sometimes get loose over time. Blowing out the heatsink vents with a can of compressed air or a shop air hose will often cure cpu overheat problems that usually causes lock ups.
Reseating the video connector on the MB can also cure a flaky video problem, but that usually entails some disassembly of the laptop.
Feb 18, 2008 | HP Pavilion dv6000z Notebook
Pc is not starting up
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
Intel D845GVSR Motherboard Logo
59 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
