Question about Epson Office Equipment & Supplies
Just set up brand new Epson Artisan 710 printer. Nozzle check went fine. Alignment went fine. Went to load more paper in the tray. After, that, the printer made a short duration noise and paper jam message showed up. Consulted instructions to clear this. No paper is visible, including in the document feeder. (The noise was actually so short that any jammed paper should have been visible in the paper tray area, not even just under the scanner.) Tried turning of the printer for a few. Now I get the message that there is a printer error and nothing will clear it, including a full repeat of checking for a jam. Decided to unplug the printer for a few. No change. The printer is brand new! Please help -- Epson support is unavailable for two days!
  • 2,069 Answers
Well paper can be caused by other parts in your printer. i would recommend you go to this page, and check out each possible cause and solution one by one. hope it helps.
regards
Posted on Jan 03, 2011
Why does my printer only print one half on a page
YOU NEED TO CHECK THAT THE ORIENTATION OF THE DOCUMENT YOU ARE SENDING IS NOT SET FOR LANDSCAPE OR PORTRAIT WHICH IS OPPOSITE TO THE PAPER LOADED.
May 12, 2014 | Epson Artisan 710 AllInOne InkJet Printer
Cd/dvd tray failurer in Epson Artisan Allinone injet printer
If you are experiencing this problem, continue as normal to print your clock then choose preferences and ensure your printer settings are ok and that it is set to print to the dvd/cd tray, then proceed to print your clock.
If you are still experiencing problems Try Solution 2..
Instead of changing your printer settings through Clock Designer, change your default printer settings. Go to the control panel in windows and open the printers section. Find the printer you are using (Actual screen shots will vary depending on your version of windows and printer)
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Epson Printer Support
Feb 17, 2014 | Epson Artisan 810 AllInOne InkJet Printer
I get the message "printer error has occurred" and please turn the printer off and on repeatedly with no change. This is the Epson Artisan 835
My Epson Artisan 810 repeatedly would give me the printer error message with the only option to turn off the unit and turn it on again. Over and over it would give me the printer error message. With the unit off, I opened the cover (like you would to replace the ink cartridges) and forced the CD tray all the way out like you are about to load a CD for printing, closed the cover, then started the unit up again. For me that did the trick. It went through it's normal 60 seconds or so of set-up, then worked fine ever since. Not sure if this will work for you, but it worked for me.
Dec 29, 2012 | Office Equipment & Supplies
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
My epson 710 artisan gives an error message that there is a paper jam or is out of paper, when I try to print a photo, it feeds through 2 blank 4*6 photo papers. There is NO paper jam when I check it, and...
Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
Jul 24, 2017 | Epson Artisan 710 AllInOne InkJet Printer
Epson Artisan 710 won't print black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results..
Thank you!!
Jun 09, 2010 | Epson Artisan 700 InkJet Printer
My Artisan 800 is having continuous paper jams, and now I think something's wrong with the nozzle or something, it seems to be having a hard time moving across and is making a crunching noise. I tried the...
please you r printer driver cd original is use. first old progreem printer driver is instol and restart pc and 10 minut wait and instoll aoriginal driver. and your printer is so the paper tray in fixed. second carteries is out of printer and so in fixed paper. and add a cartries and start printer and aply paper and aply print.
Sep 24, 2009 | Epson Artisan 800 All-In-One InkJet...
Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
