Question about Yamaha RX-V659 Receiver
My Yamaha RX-V659 no longer powers up. Once you plug it in and turn the power on, Pressing the on and standby button nothing happens. The LCD screen stays blank.
  • 4 Answers
SOURCE: Yamaha RX-V596 Receive turns off after pressing Power
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
Posted on Sep 01, 2007
SOURCE: Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Posted on Dec 29, 2007
SOURCE: Yamaha RX-V1 Power
Got the same problem and did some searching.
Strange thing is that next day the amp works fine.
This is what I found on http://www.forums.hcsd.com.au/Blah.pl?m-1210733289/s-8/
SYMPTOM: The power cannot be turned on, or the protection circuit is activated to turn off the power.
CAUSE: Fluid leakage occurs from the backup capacitor C633 0.047F 5.5V (C662 in the case of RX-V3000/DSP-AX2) on the Function PCB and causes a short with the adjacent components and between patterns, resulting in operation of the protection circuit. Fluid leakage tends to occur with this capacitor particularly with high internal cabinet temperatures, with or without the power on. Often, the leakage is only visible with very careful inspection.
SOLUTION: Two types of backup capacitors are now available with a longer expected service life. When servicing, thoroughly clean the leaked fluid from the PCB and from under any nearby components before replacing the capacitor. There are models other than those mentioned above that use the subject backup capacitor. Check them for fluid leakage and replace the capacitor as needed.
PART(S): Old
Ref. No. Part No. Description Remarks
C633 or
C662
VT740700
V3860300 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* VU545000 ELECTROLYTIC CAP 0.047F/5.5V
Horizontal type
New
C633 or
C662 WD294400 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* WD292000 ELECTROLYTIC CAP 0.047F/5.5V Horizontal type
Posted on Jun 24, 2008
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
  • 133 Answers
SOURCE: connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Posted on Sep 07, 2009
How can i locate the fuse because my AV receiver no longer powers on ?
Have you checked the wall outlet first? Then make sure the cable is firmed plugged into the receiver.
Nov 12, 2014 | Yamaha RX-V659 Receiver
Yamaha RX-V657
This will almost certainly be a problem with the power supply, a faulty part. Unless you have experience of repairs to power supplies, due to the high voltages, I suggest you take it to your local authorised Yamaha Repair Centre.
May 09, 2017 | Yamaha RX-V657 Receiver
I tried hooking up an old polk sub to my yamaha rx-v659 av receiver. smelled wires burning smell. before i could unplug it, receiver shut down. now it will power up for about 5 seconds and shut off. manual...
If a fuse was blown, it likely would have no power. However if the power board has overheated, the capacitors may have swelled up and burnt out and will only allow it to power on for a few seconds, then shut down. The capacitors can look swelled up or burnt or have burn marks on the power circuit board. You can test them with a continuity meter. Each component has a printed number of it's voltage and ohm resistance so you can test them.
Jul 26, 2010 | Yamaha RX-V661 Receiver
Hope it hasn't been fried but unit is not powering up via remote or unit power-on buttons. Have tried different power socket.
Try checking the internal fuse(s). Then check the on/off switch. The other thing to consider is the transformer.
Mar 05, 2010 | Yamaha RX-V659 Receiver
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
I HAVE A YAMAHA RX-V663, WAS ROCKING TO PINK FLOYD PRETTY LOUD AN
I had a similar problem. I have RX-V2500. No power to it when plugged it. Unplug then plug in again. Everytime you hit standby you get a click, which happens three timesand then no clicks until you unplug and replug.
I popped the cover off and just inside, where the power cable attaches, there was a white fuse. I think it was a 10A/250V (I'm in Canada), but read what the spec is on your fuse. I replaced this and it worked just dandy. Believe me - I was as surprised as the next guy.
Anyhow - hope that helps.
Obviously make sure it isnot connected to the power supply at all when you remove the cover.
Apr 11, 2009 | Yamaha RX-V995 Receiver
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Receiver turns on and clicks off when volume is raised over 8 or 9 on the dial
I had the same problem with my Yamaha amp. It turned out to be a shorting speaker wire. When I resoldered the speaker wall outlet connection it worked fine!
Feb 27, 2008 | Yamaha RX-V659 Receiver
Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Oct 27, 2007 | Yamaha RX-V595A Receiver
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
302 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
