Hi I brought a pinetron dvr camera security system. it keeps asking me to input a password to activate the system but I dont know it . Is there a standard default one please. Thanks in advance
  • Gary Griggs Jan 30, 2012
    this is a dvr not a phone and the default key is all zeros if that does not work contact hunt dvr,s here is the usa for support
sys_admin
  • 829 Answers
SOURCE: password for belkin54g
There is no default WEP / WPA key for belkin54g routers. The default password to access the setup is blank. Try going to 192.168.2.1 in internet explorer (where you would usually type the address of the site in), and see if you can find out the WEP / WPA Key.
Posted on Dec 24, 2008
  • 223 Answers
SOURCE: How to unlock the memory card..
I dont know if this will work but its worth a try. If you have a cable to connect the phone to your computer and the relevant software then try to copy the contents of the memory card to your computer and then format the card. I hope this works. Good luck.
Posted on Jan 18, 2009
RescueTechLA
  • 2653 Answers
SOURCE: System Password needed
You can clear the cmos with the jumper or just pull out the batter from the motherboard for a few minutes. That should do the trick.
Posted on Feb 21, 2009
  • 9 Answers
SOURCE: Do not have the password to unlock the TV. Whenever, I turn it on it's asking for the input password and the default is no longer 0000.
I'm not sure what TV you have but many times you can enter 5898 as the password and then it will allow you to select a new one. I hope it works on yours.
Posted on May 20, 2009
kodek_85
SOURCE: Default password for samsung GT-E2652
press key *2767*2878# gud luck!
Posted on Nov 02, 2012
How to reset my pass word on my Samsung Security Video System SDH-B74041
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
Jan 08, 2017 | Samsung Home Security
I BROUGHT A CAR WITH A KENWOOD DDX7015 THAT ASK FOR A PASSWORD
Password protection on kenwood is very good, you might need to pick up another head unit. Also after inputing the pass code you need to hold the fast forward or skip button to activate the code. I am verry familiar with that head unit and I dont know of any end arounds to bypass the security code. Get ahold of the origional owner and get their passcode or replace the headunit.
Dec 31, 2014 | Kenwood Excelon DDX-7015 Car DVD Player
How to reset the password or the H264 DVR to factory settings for Digital ID view?
Will need a model number. H264 is the compression format.
Dec 11, 2014 | Home Security
How do I connect my network recorder to my outdoor network camera's ?
Most security DVR's come with software that control the cameras. Most DVR's use BNC type connectors and unless you buy a wireless system, you will have to run cables for them.
Aug 17, 2014 | Computers & Internet
Cnb dvr password reset
Welcome To CNB Technology.
www.cnbtec.com/en/html/support/faq.php?classify=B
Ex-factory ID and Password. Ex-factory ID and ... When running DVR program, an error message comes up and the program stops. Check if the driver is installed ...
CNB DVR hard drive failure/password reset - • CCTV Forum
www.cctvforum.com/viewtopic.php?f=3&t=45061
Mar 2, 2015 - 11 posts
Hello all, I purchased/had installed for my home a camera security system using theCNB HDE2424DV and Nuvico dome cameras. It has 8 ... CNM Secure Primus (8ch) password
Feb 13, 2013
Is Q-See Equipment any good?
May 1, 2012
CnM Secure 4 Channel H.264 DVR
May 5, 2011
I need help selecting a DVR
Jan 18, 2010
More results from www.cctvforum.com
Feb 14, 2014 | Home Security
Screen wont show cameras or record
Are you pressing menu button on the monitor or the DVR?
Your problem may not be the cameras, but between the DVR and the monitor. Found this on page Eng-19 of the user manual which I found on Samsung.com
This monitor was set to password lock when you purchase a new set. Therefore, you must first enter a 4 digit password to activate the On Screen Display... the default password is 4321. Not sure if that helps.
Dec 17, 2013 | Samsung SMT-190DN 8-Channel Security...
Bought a new q see qt 428 security camera system however cant access menus, the password window keeps popping up. This the first time I am using this system..
usually the user name and password in a user manual. Please check .
sometimes, default user name and password is the same: admin
Sep 13, 2012 | Digital Peripheral Solutions Q-see...
I changed the admin password on my sentient cctv dvr from the default 123456. I saved the changes but now get the message incorrect password when I input the six digit password I stored. Please help
Hello
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
May 22, 2011 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Hi i am looking for some help and advise with the setup of the dvr box eb1304net sata. i have succesfully set up the ddns and it is set to stanley.avers.com.tw , i have also set up the dvr viewer on my PC...
You have a problem in use the same port(80) in router and also the dvr.Try change the port of the dvr to something diferent like 5550 and open this port on the router.
Nov 16, 2010 | Avermedia AVerDiGi EB1304 Net
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
