Question about Whirlpool Dishwashers
2-3 inches water left in bottom of dishwasher after it finishes it's cycle model DU81OCWDQ5
  • Whirlpool Master
  • 3,247 Answers
The model number of your dishwasher is DU810... (zero not O).
Please refer page 28 of user manual. It is normal for some water to stay at end of cycle. However, check if the air gap (if insalled) is clear. Also make sure the kitchen side of drain hose is clear.
Unless there is a fault condition shown by flashing lights, then it is pretty normal operation.
In case in future you need to refer to the parts of your dishwasher you can refer this site.
Posted on Jan 02, 2011
Seems to run it's cycle but there is a couple inches of water on the bottom after it's finished??
It's most likely not level. This keeps the drain from finishing the cycle. It will not do this if not leveled.
Dec 22, 2010 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
Water left in bottom of machine when cycle finished.
you must check filter,it is full of dirt.
it must be on front side,down left or right corner,
May 21, 2009 | Dishwashers
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Inch of water left in bottom of dishwater after done running
check for blockage starting at air gap and disposer.trace back and clean
Dec 31, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher not draining
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Dishwashers Logo
237 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
