Question about Maytag MBF2256H Bottom Freezer Refrigerator
Ice not dispensing from door. There is ice in the cabinet.
  • 29 Answers
Look behind the ice storage bin---there is a c-bracket that the storage bin slides into --- the motor may have to be replaced that turns the spiral feeder inside of the storage bin
Posted on Jan 02, 2011
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Why won't ice dispense from ice maker?
Pull out the ice storage bin from the refrigerator. Empty the bin if it is full. Add some ice into the bin. Reinstall bin into refrigerator. Make sure the refrigerator door(s) are closed. The ice will not dispense if the door(s) are open. Press the ice dispenser with a glass underneath it to start dispensing ice. Listen for a whirring sound. If there is a sound, then the auger that moves the ice cubes is working. Check the ice shoot in the door to see if it is blocked with ice. If you don't here any whirring sound the motor that runs the auger is probably bad. Then you will have to replace the whole ice maker assembly.
Jul 20, 2014 | GE Refrigerators
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
GSH25KGRWW dispenses ice/water all by itself! Heard noise last night, and refrigerator was dispensing ice all over the floor!! Attempted to stop by tapping the lever, but this had no effect; pushed water...
as you explained that by opening the freezer door the problem stopped the problem is: that you have a pinched dispenser wire or, two in the area between the door and, the door opening
these wires are low voltage so they are not going to cause a fire
but, if they touch the cabinet due to a bare wire they will ground and, start running the dispenser.
the door cover needs to be removed and, the problem (usually at the door hinge must be found and, corrected i.e. wire taped, shielded etc.
Sep 14, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost in freezer
The door seals on the refrigerator and freezer doors will not cause the frost at the ice chute. Frost will build up where warm moist air meets cold air. Your ice chute door seal is bad, so you need to replace the ice chut door. As far as your door gaskets go, clean the gaskets and the mating surface of the refrigerator and freezer cabinet. Use a hair dryer (NOT a heat gun) to heat the door seal up anyplace the dollar bill was loose. The magnet in the gasket will pull tight to the cabinet once the heat has softened it up. Do not open the door for 30 minutes or so to allow the seals to cool. You would only want to replace the seals if they are torn.
Jun 05, 2009 | GE Refrigerators
Connected water supply and confirmed good water pressure. cannot get water to dispense or icemaker to make ice.
Hi, When you push the water switch in the door, do you the inlet valve humming? Is it possible that the wires came off the inlet valve?
If you remove the inlet valve from the cabinet and unhook the large size tubing that leads to the water dispenser, you can engage the dispenser lever in the door and see if water comes out.
I hope this helps you. Please let me know if I can assist yyou further.
Vic
May 31, 2009 | Refrigerators
NO WATER COMING OUT FROM WATER DISPENSER
This could be a bad water valve for dispenser on back of fridge or poor connection in the dispenser control. If you could get me the model number I will be able to help you better. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MBF2256H Bottom Freezer Refrigerator Logo
79 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
