Question about Sony KV-32FS13 TV
1) I have a Sony KV-32FS13 that has a green tint in the picture. Does any oneknow how to access the service menu for this model? I tried other adjustments and I can't get rid of the annoying green tint. 2) The standby light is also blinking a code 5. Anyone know what it means? Any help will be greatly appreciated!
  • Matt
    Matt Jan 02, 2011
    Thanks, I am leaning more towards the AKB circuit problem. I just noticed when the screen is white or mostly white (or a different bright color), the image gets very bright and everything has a strong red or green color to it and it is almost like there is no blue.
    President:
  • 2,992 Answers
Code 5 is "AKB error". AKB, or auto kine bias, is a cicuit that monitors the three color guns of the picture tube (red, green and blue) and tries to adjust them for proper color balance. If it can't, the picture is blanked (usually) and the timer/standby light blinks 5 times. When the color drives aren't balanced, you see a color tint in the picture like you're describing.
There might be a problem in the AKB circuit, or the picture tube may just be old enough that the AKB circuit has run out of adjustment range. If the tube is at fault, you should consider replacing the set. A new tube will cost nearly as much as a new 32-inch LCD TV, and you'll need to pay someone to install it and set it up. There are special tools required to perform the convergence which gets the color guns aligned with the face of the tube so they hit the right colors.
If you'd like to try tinkering with the service menu adjustments, this site explains how to access the menu and gives a list of settings.
Posted on Jan 02, 2011
  • Matt
    Matt Jan 02, 2011
    I thank you so much for how to get into the service mode. I think it is an AKB circuit problem. I notice when the screen is completely/or mostly white, the greens and reds become very bright but it is almost like the blue isn't even working.
Sony trinitron FV-32FS120 picture has an orange tint
THERE ARE ADJUSTMENTS TO THE VIDEO DRIVE THAT CAN CORRECT THIS PROBLEM/THEY ARE IN THE SERVICE MENU. WITH THE POWER OFF, PRESS MENU-5-VOL+ POWER THE SET WILL COME ON IN THE SERVICE MODE. STEP THREW THE MENU ITEMS UNTIL YOU GET TO RED/GREEN/BLUE DRIVE THEN ADJ. TO BALANCE THE COLORS WHEN DONE PRESS MUTE TO STORE THEN POWER OFF ON THE FRONT OF THE SET OR IT WONT SAVE.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS13:Pictured slightly bowed down at sides
Your symptoms sound like you have a problem in the pincushion circuit.
I would recommend you have a technician take a look at this, as this can be a tricky circuit to trouble shoot.
Aug 15, 2009 | Sony Televison & Video
Sony Trinitron, no picture, sound works fine.
There are potentially dangerous high voltages present inside the set even when unplugged, so caution is required. That being said, if you can solder, you may be able to resolve this. If the picture returns with movement, it is possible that the problem is poor solder connections. Try removing the back and sliding out the main board. Resolder any connections that appear grasiny or have rings. That may resolve the problem.
Keep us posted.
Dan
Feb 03, 2009 | Sony KV-32FS13 TV
I wanna change the housing of my KV-32FS13 cos' I broken it. I want know: Where can I buy it? and the price...
The part numbers and costs from tritronicsinc.com are listed below.
Dan
407565401 Cover, Rear $55.52
x40390032 Beznet Assy w/menu buttons $82.12
Dec 29, 2008 | Sony KV-32FS13 TV
Blocked - Unrated Programs
Hello Mary Lou,
The (USA) UNRATED feature ... MENU selectable
Opts: BLOCK/UNBLOCK
Index says this starts on page 31 ... (it doesn't seem so)
but I found it at the bottom
of page 38 (see below)...
(sorry this is the worst display of a manualslib display)
Sony KV 32FS13 Operating Instructions Manual Page 38
You may page up & down...
I do READ... it is supposed to be MENU selectable...
GENERALLY I have gotten rid of this non-sense & password locks by skipping to the
END of the instructions and doing a GENERAL RESET.
Hope this helps.
Carnac the Magnificent
Jun 07, 2017 | Sony KV-32FS13 TV
Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony KV-32FS13 TV
SONY KV-32FS13 No Power.. No nothing
has a power supply or deflection fault requires service
Mar 16, 2008 | Sony KV-32FS13 TV
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Sony KV-32FS13 TV Logo
542 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
