Question about Refrigerators
All fans seem to be running properly however it is not cooling either freezer or top refigerator
  • 1,772 Answers
Uiui
yui
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Jan 02, 2011
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Refigerator not cooling and hot to the touch
It sounds a lot like lost charge caused by a leak in your system. If your unit has been moved or improperly cleaned, some part of the pressurized system may be damaged.
Refrigerant (with very small molecules) may leak off over many years but it shouldn't happen in the single digits.
Apr 05, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Frigidaire Refigerator
TEMP FIX i found remove hinge cover top of left door and unplug the Icemaker and fridge will run again havent figured out the problem with icemaker yet though
Feb 18, 2008 | Refrigerators
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
