Question about Iomega (33654) Limited Edition 500 GB USB Hard Drive
I can see my iomega external usb drive in device manager but not in my computer also has no bootable sectors no mbr either how can i format it so i can use it
  • lesley decker Jan 07, 2011
    tried that befeore i gave you 5 bucks lucky you
  • 2,069 Answers
Use the Disk manage utility. right click on my computer icon on desktop ( if you are running xp), click on manage, then choose disk management. all installed drives will open , identify your Iomega disk on the right lower hand side, right click it and choose format. all should be ok after.
regards
Posted on Jan 07, 2011
  • 335 Answers
Right-click 'computer' or 'my computer' (in xp) and left-click manage. Next, click on disk management, and from there you should be able to partition the drive and format it.
Let me know if this doesn't work and I can help further.
Regards,
Joe
Posted on Jan 02, 2011
External drive does not appear on the desktop. I have had this hardrive for about a year and a half and it is about at half capacity. When I plug in the USB to the computer the light on the device comes on...
Iomega portable hard drives connect to your computer through a USB port.
When you connect the Iomega hard drive to your computer, it should pop up as an icon in your
My Computer folder.
If you can't find the icon in your My Computer folder then you probably need to update the driver for the device.
Updating this driver is not very hard and can be done automatically from the Windows Device Manager.
Plug your Iomega hard drive into one of your computer's USB port.
Click the "Start" button and go to the "Run" field.
Type "Devmgmt.msc" into the Run box and press the "Enter" key.
Go down to the bottom of the device manager to the "Universal Serial Bus Controller."
Click on the little + (plus) sign to expand it.
Look for an entry with a yellow exclamation point and click on it.
Click the "Install the software automatically (Recommended)" button and then click the "Next" button.
Click the "Finish" button when the installation has finished.
Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon.
Double click the icon to gain access to the external hard drive.
Sep 08, 2013 | Iomega Silver Series 320GB 3.5 External -...
Iomega 80GB external HDD not read because of I/O errors. This occurred after the drive was checked for volume errors
Try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files. download it from
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html
Sep 07, 2011 | Iomega Portable 80GB 4200rpm 480Mbps USB...
When I open up my Iomego eGo Portable Hard Drive it shows as Omega Encryption Utility and under preferences 0 bytes available. How did this happen and can I just delete this? I tried to reformat and...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jun 22, 2011 | Iomega eGo Portable Hard drive 500 GB ...
Iomega external HD not recognized?
try to access the drive forme a live cd, like puppy linux, it should be regonised in the format tool called g parted.
if your are not familior with linux, you will need winpe mini cd, **** you need to be carefull about loosing data in the drive, coz you might want to format it and clean all the bad sectors and clusters before using it.
May 09, 2010 | Computers & Internet
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Can't format new Iomega 1 TB drive on a mac
the mbr has been lost and may be the boot files too. this happens if sector zero is bad or weak
use a windows pc .and remove the raw drive from the casing of this external drive. now hook it into the windows pc and see for the drive detection in bios. if detected the drive is ok and needs a good low level formatting. with a llf tool you can get one free from hddguru.com
Sep 18, 2009 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Unreadable fujitsu 160 gb mhy2160bh
Some HD manufacturers provide utilities for Disk Recovery. You can usually download these from their site. If you are lucky it is just the drives Master Boot Record that is damaged. The fact that the drive is recognizable is in your favour I think. Unfortunately when power is restored after an outage there is often a power surge or spike on your AC which can damage electronic equipment. Many devices these days work on such low voltages and current that it doesn't take much. A good surge protector is a must for computer equipment.
Dec 08, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
Please check in device manager that storage mass device is not showing yellow mark if it is please first remove any storage device showing yellow mark in usb devices in device manager >
You wil find device manager in windows 2000/xp in control panel >administrative tools>computer management ..then click on device manager
Second thing is please remove/uninstall any storage device information from device manager
Restart the pc and then go to device manager and see there should be no entry of storage device in usb root devices .After this fix your usb device and it will work definately
Regards
Balisonu79
Feb 13, 2008 | Iomega Zip 100MB (31714) External ZIP...
Iomega (33654) Limited Edition 500 GB USB Hard Drive Logo
139 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
