Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
You must initialize a disk before Logical Disk Manager can access it.
4 Suggested Answers
SOURCE: disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Posted on Mar 12, 2009
Crankstart
  • 696 Answers
SOURCE: Verbatim 250 GB drive suddenly not recongnized
Sounds like either the HDD or the USB controller card is almost dead.
Sorry for the news, if it is the USB controller you should be able to have the drive transferred into a new enclosure and continue using it. However if it's the circuitry on the Hard drive itself you may be in need of more serious assistance.
You can take the drive to most computer stores and have someone tranfer it into a new enclosure if you need the data and don't mind the risk of voiding your warranty. If that doesn't work, let me know and I can point you in the direction of a service company that can attempt to extract you files from the damaged drive.
Chris
Posted on Apr 26, 2009
  • 54 Answers
SOURCE: USB External Hard Drive cannot access. Disk
If the drive is available, with a blue bar in disk management, just right click on it and select 'change drive letter and paths'. This will allow you to assign your own drive letter.
If you have more than one external drive or if you use daemon tools, powerISO, they may be trying to occupy the same drive letter, which would explain your problem...
If you see a black bar, it would seem your partition was corrupted and you would need to try and recover your data, if necessary (recuva recovery software is an option) and then repartition the drive.
Hope this helps!
Posted on Jan 27, 2010
Why C-D030 error happend?
All CD errors are hard disk errors, likely to mean it is unformatted or corrupted.
The following process allows you to reformat the hard disk.
Think carefully if you want to commit to doing this. It shouldnt cause any problems, Ive had to do it on a couple of our printers in the past with this and a different CD code.
Use:
• When the hard disk is mounted.
• When the hard disk is to be initialized. (Physical Format to Logical Format)
Adjustment
Procedure
1. Call the Service Mode to the screen.
2. Touch these keys in this order: [State Confirmation]
- [Memory / HDD Adj.] - [HDD
Format].
(1) Physical Format
1. Touch [Physical Format].
2. Press the Start key to start the formatting sequence.
3. The sequence will be automatically terminated as it is completed.
4. Turn off the Main Power Switch and turn it on again more than 10 seconds after.
(2) Logical Format (Only when initial is set up)
1. Touch [Logical Format].
Jun 05, 2014 | Konica Minolta Office Equipment & Supplies
Lacie disk mini full
Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. Right clicking will give you the options of initializing, creating disc partitions, assigning logical drives, and formatting.
Sep 15, 2012 | LaCie 1TB ETH DISK MINI HOME EDITION REM...
DX4850 doesn't detect dvd drive. It doesnt show on "my computer"
Check to see if it is detected in "Device Manger"
  • Right Click "My Computer" > Properties
  • Click on the "Hardware" tab
  • Click Device Manager
  • Check to see if you shows any devices with yellow ! or ?
If you see nothing at all for a CD/DVD drive then it's mostly just bad and needs to be replaced. Press easy replacement. Here is a tutorial. I would rate it a 2 out of 10 for difficulty. http://www.ehow.com/how_4814466_replace-computer-dvd-drive.html
Comment back if you need further assistance. Thanks!
Aug 12, 2011 | Gateway Dx4850-45 Desktop Pc
I have a HP pavilion DV6 laptop with preloaded windows 7 home premium and 4 primary partitions. The windows partition is the third one. Now, I want to split that partition. But, windows does not let me do...
Use the free partition manager form EASEUS. Convert the partitions #3 and #4 into logical partitions containded both in the same extended partition (you can have only one extended partition, but it can contain multiple logical partitions, each with its own drive letter asigned)
Now you can using the same EASEUS to split the patition you wanted.
Aug 06, 2011 | HP Pavilion dv6-1122us Notebook
My usb ports have power but my devices are not being recognised
Hi t dillman523...
The problem is probably being caused by the Logical Disk Manager
Administrative service and possibly the logical Disk Manager service
not being started or the services might be disabled.
To solve the problem, click on the "Start" menu, click the "Run" command, and then type
in the box: services.msc , scroll down until you see both the above services.
right click on each of the services about and select properties, on the
general tab, change the startup type to "automatic" and click the start
button under the service status. do this for both of the services, and
that should will fix your problem."
For Windows 2000 and XP:
Right click on My Computer.
Choose Manage (This will open the Computer Management window).
Go to the Storage category and select Disk Management
Right click the new drive (usually listed as Hard Disk 1) and "initialize"
You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended
Please take time to rate me
Jul 31, 2011 | Compaq Presario M2000 Notebook
Hi All,\r\n My Laptop model is Lenovo 3000 series Y410. I do have Windows XP SP2 installed. In the Disk Management, I am not able to see the hard disk partitions and also not able to install the Windows 7...
1. Boot from (Win 7) disk>select language>accept license terms and agreements>advance disk drive options>select from a list of partitions available there
2. Check if the “Logical Disk Manager “ and “Logical Disk Manager Administrative Service” are automatic and started under services.msc, and
3. To go to the following link and test the hard drive of the notebook:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70578
Please try this out, and the inform back with further details
Jun 17, 2010 | Lenovo 3000 Y410 Notebook
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
How to create a logical drive in windows vista home basic?
You must be logged on as an administrator to perform these steps.
To create a partition or volume (the two terms are often used interchangeably) on a hard disk, there must be either unallocated (empty) space on the hard disk or free space within an extended partition on the hard disk.
If there is no unallocated space, you can create some by shrinking an existing partition, deleting a partition, or by using a third-party partitioning program. For more information, see Can I repartition my hard disk? For more information about reformatting a hard disk, see the "What is reformatting?" section below.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 31, 2009 | Microsoft Windows Vista Ultimate Edition
Creative stone plus
Initially, it would be possible that the Zen Stone plus is infected with a virus and your PC's antivirus is preventing access to it. Have you tried a reformat of the Zen Stone plus and or a virus scan?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 07, 2008 | Creative Labs Zen Stone Plus MP3 Player
I am getting logical disk on host twice
Are you sure that our logical disk is not mapped twice to your host channel on your MSA 1500? If it isn't have you tried a power cycle to the storage array and a clean shutdown/restart on your host?
Apr 24, 2007 | HP MSA1500
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
1,357 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
