Question about LG Washing Machines
How to reset closing latch of wd 8130c - LG Washing Machines
I have a 2006 malibu anti theft keep going off. Had to unplug the battery just to stop running out side ever 10-15 mins. How to reset it?
The battery must be disconnected at least 20 minutes to allow the power in electrical items to dissipate. When you reconnect, the immobilizer _should_ reset itself.
Feb 04, 2016 | Cars & Trucks
When it's cold out my doors won't stay closed
lubricate all door latches and hinges (GENEROUSLY) with WD 40, repeatedly open and close doors until latches are working good.
After doors are closing as they should respray all latches and hinges with lithium grease. If this does not work replace latches and have door hinge pins checked.
2009 Hyundai Accent grease and lube all latches
How To Fix Sagging Door Replace Hinge Pin Bushings Monte Carlo Grand Prix
Jan 10, 2016 | 1993 Dodge Dynasty
My driver side door won't close in privia van
Check door latch point on your door. It maybe in closed position. Take a small screw driver or needle nose pliars and open latch. After you open latche then spray with a dry lubrcant such as graphite or wd 40 spray. Also lube locking latch on car frame
Sep 20, 2015 | Cars & Trucks
Chrysler pacifica trunk
You need to replace that latch, I think the return spring must be broken.
Jul 28, 2017 | Chrysler Pacifica Cars & Trucks
Hood will NOT shut or latch close
make sure the cable is moving freely then spray wd-40 on the latch assembly and move it back and forth with a screw driver
Aug 24, 2012 | 1998 Chevrolet Prizm
Latch on driver door is closed door will not latch closed
Pull the door handle and with a screw driver pry the latch to open at the same time.
Feb 27, 2011 | 1993 Chevrolet Lumina
My door ajar light stays on in my ford f150 king ranch crew cab
Have you tried WD-40 in the door latch ? Some times the contacts in the door latch get gummed up, and the door switch stops working. A good soaking on the door latch, and close / open a few times and another soaking of WD-40 usually does the trick with the door latch switch.
Jul 10, 2010 | 2003 Ford F150 Regular Cab
My hood will not close completely it closes and to the first little safety latch but not the main one
Alot of times you have to push the tee bar "Black" safety latch back first then close the hood
Jul 02, 2009 | 1998 Volkswagen Beetle
Hood will not close completely on 1996 Tahoe
Try "resetting" the lock. With the hood open-lube the lock good with wd-40 or similar and go pull the hood latch handle several times. See if it works good when your done. If not ,something may have got bent from closing attempts. Will have to look at adjustment then. Hope I helped. Thanks
Apr 06, 2009 | 1996 Chevrolet Tahoe
Washing Machines Logo
44 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
