Question about KitchenAid Ovens
Just moved to a 10 yr old house with KitchenAid KEBS208DSS8 oven. Top one working as expected. However, the bottom one does not heat up. Fan & light functions for the lower one in working condition but no heat with the control panel showing LO instead of temp reading. No other error code on startup except for PF. Read online that suggested the culprit is the fuse (thermal cutoff) in the back. So, we swapped the top with the lower one and top and the result was the same (top=functional, lower=no heat). Tried to bypass the fuse in the lower one but still no heat. Starting to suspect the control panel at fault but unable to enter diagnostic (off, off, start). Any suggestions? Thanks in advance.
SOURCE: OVEN will not heat
I have the same model, 3 yrs old, and the exact same thing happened. KitchenAid made the appointment with a repair company and when the tech came out the first thing he said was "you can never use the self cleaning cycle because this always happens.' He replaced the thermal fuse thermostat and said that a lot of times the digital panel will go out and that will cost around $400. The cost of the thermal part was $80 plus his $90 labor charge. I called Kitchen Aid back, and they swore they never heard this complaint...all you have to do is look on line to see it is a major complaint!
Posted on Nov 02, 2007
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Posted on Dec 24, 2007
aborcass
  • 2651 Answers
you need to remove the oven from the cabinet, the fuse is located on back wall about 6 inches down directly between broil element leads
Posted on Feb 24, 2008
SOURCE: Top oven will not heat up
JKP55 The top oven would not heat. Got it fixed for $261.00 with tax. The bake element in the upper oven was bad. My oven unit is 14 years old.
Posted on Feb 07, 2009
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Posted on Jul 17, 2009
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Whirlpool oven not heating up, though grill, fan and light still
Hi.
If fan in oven is working o/k, then the prob is most likely the oven element is faulty, and needs to be replaced.
Please rate my solution.
Thanks.
Aug 20, 2009 | Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Smeg sp9000x.2 double oven - no heat from top oven
hi
the changes are if the fan is turning and light is on then the element around the fan will need replacing hope this helps
regards dan
Mar 19, 2009 | Ovens
Botom oven not working
Hi
The oven element is probably faulty, I assume the fan is still working.
Nov 23, 2008 | Ovens
Zannusi built in oven
Solid line at top indicates the grill. Two indicate the oven.
Sep 21, 2017 | Zanussi ZHQ575 Electric Double Oven
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Ovens Logo
59 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
