Question about Sharp AL-1655CS Laser Printer
Image duplication my numbers/letters are getting a shadow image almost 3 dimensional
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Replace the fuser unit..
Posted on Nov 21, 2008
Shadow copy
Need a little more info but if you are using a laserjet printer shadows or duplicate images usually come from worn out rollers in your fuser. Depending on your model fusers are available by themselves or as part of a maintenance kit. Replace the fuser and that should take care of the problem.
Nov 02, 2013 | Sharp Toner Digital Copiers Ar M355 M351...
Alignment is not the issue with my printer... i keep getting a shadow behind my letters and images I print, but not on typed documents... only scanned ones or copied and pasted images into word... so...
The shadows are common from scanned images. You might want to hold the book you are trying to scan in a better angle so that the scanner can read it more clearly. Then your scans won't have that many shadows.
Mar 06, 2011 | Office Equipment & Supplies
Tv is showing shadow images
You have defective convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
May 10, 2010 | Televison & Video
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Image has duplicate shadow
There should be different HDMI slots on the back of that TV. Switch you HDMI cable to use another slot. Change to that HDMI slot on your TV menu. Sometimes the ports go bad, or there is something messing with the signal.
The HDMI can carry sound and video. Make sure that in your tv menu that your tv is setup under audio has the receive audio from hdmi as well.
Sep 22, 2009 | Televison & Video
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
Tv duplicate image
your guns are off and need to be adjusted. your 3 guns (red, green and blue) are off and that would explain the funny colors and shadows. Have a tv tech come out and have a look, they can fix it for a reasonable price.
Oct 20, 2008 | Televison & Video
Shadow/duplicate printing
in computer goto printer setting mode and uncheck option
toner saving mode and check out for dark or light effect
Jan 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
Color distortion
There are failures occuring in the scann and convergence circuits. This may not be feasible to service.
Jerry G.
Dec 14, 2007 | Sony KP-43T90 43" Rear Projection...
Printouts with shadow
Two things - Fuser or cartridge - stop print halfway in machine, if fault occurs before paper has gone threw the fuser then it is a faulty cartridge, if print is ok before fuser (the hot bit at rear) but gets doubled up after fuser then the hear roller in fuser are faulty change fuser....but 95 % of the time it is due to dodgy refill cartridge or worn cartridge (the rubber blade inside cartridge fails to apply enough pressure against drum to clean away old image  hence duplicating itself onto your nice clean paper! Try a known good cartridge if in doubt..
Oct 16, 2007 | HP LaserJet 1300 Printer
Sharp AL-1655CS Laser Printer Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
