Question about General Electric DHDSR46EGWW Dryer
Start switch clicked, went dead. little puff of smoke came out of the back of the unit, at the same height as the on/off switch. I pulled the 220 plug immediately. Is this a fuse problem? (oh please)
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
No, by the smoke you saw, you dont have a fuse issue. you must have had a relay or switch burn out. and something in the unit caused the problem.
could be a bad heat coil.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Engine gives off a little puff of smoke on startup
What size motor? Older engines will start to have valve guide wear and this can cause a small amount of oil to seep into the cylinder after the engine shuts off. This will cause a small puff of smoke on start-up. If the smoke clears up immediately, there is really no major problem. Be advised that on the GM motors, it is the back two cylinders on the v-6 and v-8 engines that this usually occurs. As the condition worsens with age, the oil can cause plug fouling resulting is misfiring. Changing or cleaning the affected plugs will remedy the issue for a while.
Aug 05, 2014 | 1999 Chevrolet Silverado 1500
Puff of smoke from air vents.
You have a better idea than us, you saw and smelt the smoke.
Nov 01, 2017 | 2000 Ford Taurus
Smoke...screen blinking
The circuit board or display board is burned out. There is nothing you can do, take it to a Brother repair shop. Ask for an estimate, it might be expensive.
It might still be under warranty... Look at you bill of sale and check your warranty regarding electronic parts.
Feb 09, 2010 | Brother SE-270D Computerized Sewing...
TV went puff, completly blank a little smoke and a
Probably going to cost more than a new one is worth, and then you have still got a "Fixed" unit & in my experience once things start to fail there often is a domino effect. Still if you can get a free "Quote" for a fix, get one and see?
Jan 27, 2010 | Televison & Video
Bike will turnover but not start. It happened at
Sounds like either you coil went bad, the ignition module...or a wire shorted out
Aug 27, 2009 | 2005 Buell Blast
Wiring problem, puff of smoke came from hazard button
I have got the smoke *** well from hazard button. The fog lights switch was melt.
May 26, 2009 | 2005 Chrysler PT Cruiser
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
If I try to drag something into the dock it disappears...
Drag the file you are trying to put into the dock to the right of the silver line at the right of the dock. The file you want to delete, let it disappear in the 'puff of smoke' and then go into Macintosh HD and find the file and drag it over the trash icon. I hope it works!
Thanks, Logan
Jan 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Put US-made 120 V Toshiba into 240 V electric current. It blew.
Did the smoke come from the computer or the power supply. Most of the power supply boxes for notebooks are multi voltage and can auto switch from 110 to 220. If the smoke came from the power supply box it may not have damaged the computer. If it came from the system, the power stage of the motherboard cooked and it will need replaced. If it is an older laptop it will probably not be worth fixing as it may cost more than half of the cost or a new one. I would try using a different power supply to test it and see if it comes on. If not, you may be looking at getting your data transferred to a new computer.
Best of luck
Cheers
Jan 01, 2009 | Toshiba Satellite A105 Notebook
Heard a pop when I started it, now no blower or blinkers
sounds like the ignition switch shorted out like a wire was rubbing and im sure it blew the fuses your going to replace the egnition switch and repair any wire thet is bad and replace the fuse
Nov 14, 2008 | 1992 Dodge Caravan
General Electric DHDSR46EGWW Dryer Logo
51 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Harry Roberts
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
