Question about Mega Bloks Probuilder Authentic Definition Harley Davidson V-Rod
I need to get the instructions for the Sea Plane and Rescue Boat that was part of the Sea Rescue 9741. My son has the Sea Rescue plan but it didn't come with instuctions to build the other two.
2 Suggested Answers
  • 75 Answers
SOURCE: assembly instuctions to build racing rig pro builder mega bloks
You can get the instructions from the Mega Bloks wiki, Blok City.
Follow the link below and then go to the bottom of the page and the instructions are there.
http://www.blokcity.com/wiki/index.php?title=9744_Racing_Rig
Posted on Jan 04, 2012
I need to kniw start out driving instructions for my bayliner sierra 2855. I need to start with trim all the way up. And adjust down as I plain out or opposite way.
Start with the plane pads in just past level in the up direction. As you plain the boat bring them down slowly not to go to far.
Jun 19, 2015 | Cars & Trucks
What to do to get boat to plane out
Try adding a plane to the lower unit of the outboard motor.
SE Sport 200 Hydrofoil
This will plane out the boat quite well.
Jan 05, 2015 | Boating
Stratos bass boat
Is your speedometer working? If not, the pick up tube may have come off and is dripping water in through that.
May 02, 2014 | Boating
My evenrude mo# te150gleis starts but idles rough and wont get the boat to plane what are some possible issues to look at thanks
Put in some "sea foam" fuel additive and see if that is a help, I've also cleared some gunk running the choke while at full throttle (unless this has the enrichment system). That creates a great vacuum- and may **** the remainder of stuff from the jets. Otherwise you will have to rebuild your carbs.
If you can find the idle jets, remove them and put carb cleaner directly in the holes - then re seat them and adjust in the water for best idle.
Check your compression and spark for possible ignition issues and old "run hot" damage.
Aug 02, 2012 | Boating
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Nov 16, 2017 | Humminbird 586c
Need the 6bdc battery pack for tyco sea arrow
there should be a battery box that holds four AA batteries. The box fits in the boat.
May 11, 2012 | Tyco Radio Control Sea Arrow Boat 27mhz
Boat does not plane
you could try a lower pitched prop.2" would up the revs by 400 revs.,which would up the revs ,but give you more low down thrust,and/or tucking the motor under more[if you have electric trim/tilt].thats a big boat and fair bit of weight for a 40hp..my 40hp merc is on a 13ft saracen,and with two of us it takes a while to get gooing.so i bought a ProPulse prop,with adjustable pitch.been god to try different pitches
Jul 10, 2010 | Light Outboard Motor Boat Bass Fishing...
PLaymobil jet wings come off and missing a piece.
For an inventory, see the set page at PlaymoDB:
http://playmodb.org/cgi-bin/showinv.pl?setnum=4310
The link "Show text-only list with quantities" will tell you how many of each are in the set.
If you need the plans, see the PlaymoDB FAQ for direction on ordering paper plans from Playmobil.
http://playmodb.org/playmodb_faq.html
Dec 10, 2009 | Playmobil Jet Plane
Why are Aluminum Fishing Boats the Best Fishing Boats?
A timber boat is high maintenance. Trust me, I've had quite a few. You're always sanding timber, varnishing timber, repairing timber and lots more. Now if you're happy to be doing that then that's great, but recognize that's the price you pay for a great looking timber fishing boat. And a timber boat is often heavy, and will not last well, particularly if you aren't as diligent with your maintenance as you could be. And they puncture easily when you hit something, as I did last week. But if you're not an enthusiast for working on boats then timber isn't your best choice. What you want in a fishing boat is this. It needs to be tough. It needs to be low maintenance. It needs to be puncture resistant. It needs to last forever without spending hours working on it. It needs to be easily repairable. And it needs to be cost effective. For me the best choice fishing boat is an aluminum fishing boat. Aluminum has properties which make it the perfect material for building fishing boats. It is very light and strong for it's weight, and can be easily welded, so is ideal for both building and repairing. It is extremely long lasting, and is very resistant to puncture. Now of course that doesn't mean it can't be damaged, as it can. But you need to hit it pretty hard to do some serious damage. And if you did that to a timber or fiberglass boat it will be very seriously damaged. And an aluminum boat may just dent, rather than fracture, so you can head right back home with nothing more to show than a dent, instead of possibly be the subject of a rescue from a sinking boat. And it lasts forever if treated right. If you get a great aluminum fishing boat and treat it well you may well find yourself leaving it to your kids. Because aluminum boats are light for their strength they often need a smaller engine, and the engine is probably the highest cost item. A smaller engine costs less, and uses less fuel. And with a smaller engine they are also lighter and easier to handle. And they require little maintenance. Make sure you hose your boat down after a day out, especially in saltwater, and if you drop a lead sinker make sure you pick it up, as it's not great to leave any other metal in contact with aluminum, otherwise you don't need to do too much maintenance at all. More fishing time. And because aluminum boats last so well they also retain their resale value well. I bought a used aluminum fishing boat 2 years ago and it is currently worth a little more than I paid for it. So there's plenty of good reasons to buy an aluminum fishing boat. Unfortunately they aren't cheap if you want to buy a new boat, but for the same reasons I've mentioned above, it's way better to buy a used aluminum boat, as a used boat is usually much cheaper than a new one, and retains it value well. I would never buy a new aluminum boat. So grab yourself a great used aluminum fishing boat and get fishing this summer, it's the best way to get on the water.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Load back the fisihing boat on the trailer
Float on style trailers are designed with immersions depths and vertical guides to allow the boat to be driven onto the trailer. But not at full throttle, only enough power to move the boat over the bottom rollers/guides. Some trailers are designed t
Mega Bloks Probuilder Authentic Definition Harley Davidson V-Rod Logo
64 people viewed this question
Top Mega Bloks Toys Experts
Nikki  Mclean
Nikki Mclean
Javier Segura
Javier Segura
Level 1 Expert
matt
matt
Are you a Mega Bloks Toy Expert? Answer questions, earn points and help others
