Question about Motorola Mobility RAZR V3
All keys except power are locked up.
Already tried to power down and pull battery, still no keys work including side keys and arrow keys. I can only turn it on and off.
    Problem Solver:
  • 15 Answers
Did u drop any liquid on the phone because it can cause a problem
Posted on Jul 10, 2008
Arrow keys locked
Power the computer down and unplug it. Remove the battery for about 10 seconds. Reverse and try safe mode again.
Jan 22, 2014 | IBM ThinkPad Computers & Internet
I own a '99 Range Rover 4.6 hse. I recently reinstalled a battery that had gone dead. I cranked the engine but the alarm went off and the vehicle did not start. I am getting this message: gearbox fault. I...
Unfortunately, there is a trick to replacing the battery.
1) Open the Driver side door.
2) Open the Bonnet and take the battery cover off.
3) Use your remote to lock and unlock the car (keeping the driver side door open)
4) Pull the Negative Lead from the battery first, followed by the Positive Lead.
5) Change or replace with charged battery.
6) Closed down Bonnet.
7) Your windows, sunroof, and key FOB will not work... so follow the next steps.
7a) Insert your key, with door closed into the exterior lock on driver's side.
7b) While turning the key to lock the door, hold down the "lock" button on your remote for 5 seconds while in "lick" position
7c) Your remote will reset, and you should be able to use your remote now
7d) While driving, roll each window down twice. On your third attempt, you should only have to touch the window button, and the window will have reset
Enjoy your Rover!
MIke
May 21, 2010 | 1999 Land Rover Range Rover
2001 Explorer; anti theft light steady; no power to car
take the positive side of the battery off for about 3 seconds and then put it back on to see if this will reset the security code
Apr 26, 2009 | 1994 Ford Explorer Limited
2001 Honda Civic power door locks no longer work
I have the same problem. The battery in the remote was replaced, still cannot operate lock. I can operate the balance of the door locks from the inside, except for the drivers side. I manual have to push or pull the door lock.
Apr 23, 2009 | 2004 Honda Civic
74 pace arrow fuse box wiring diagram
you do have about half dozon fusable links that may have fried or battery maybe bad. check first master fuse is usually under the hood (if you havent looked already) on the passanger fender next to headlamp or firewall for the main fuses. take a test lamp if you have one and turn key on and see if there power on both posts if power is available one side only then pull that fuse and check to see if it blown
Apr 07, 2009 | 1983 Dodge 600
Screen goes to half light when on battery power
i know if you hold the fn key in the bottom left of the keyboard and press the up arrow it will get brighter. the down arrow makes it dimmer
Jan 30, 2009 | Dell Latitude D600 Notebook
Central locking not working new battery in remote no help my car is now super locked and I can not open the lock for any door except the drivers side and then only with the key... this has become a one...
There are 2 possibilities. First, if you have the EKA code, this is the emergency key access code, a 4 digit number. You must lock down the car including windows and then with the key enter the code using the door lock on the drivers side. Note that if you miss with the code 3 times, then you will have to wait about half an hour to let the system reset, before trying again. Check your vehicle service books to find the code, maybe on a seperatre card. The only other option is to recdover the car to an authorised dealer that can plug in the tester to reset the system.
Hope this helps
Dec 29, 2008 | 2003 Land Rover Discovery
Tv signal locked
A: The TV is in Showroom mode. The following steps will help you switch to Home mode. 1) Press Menu button from the remote,
2) Press Down arrow key until you see the word Picture, then press the Right arrow key,
3) Press Down arrow key until you see Mode, then press the Right arrow key,
4) Press Down arrow key until you see Power Up, then press the Right arrow key,
5) Press Down arrow key until you see Home, then press the Enter key,
6) Press Menu button four times to exit out from the OSD Menu.
Dec 10, 2007 | Olevia LT27HVX 27 in. LCD Television
Top left side of the monitor asking for a key dats monitor locking so i need to open the lock plesae help me
Try holding the menu button down, this works for most monitors, just hold it down for at least 1 minute or so
Mar 16, 2007 | Thomson 20LCDB03B 20 in. Television
Motorola Mobility RAZR V3 Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
