Question about Panasonic NN-S563 Microwave Oven
Microwave stops after approx 20 seconds - Panasonic NN-S563 Microwave Oven
  • Panasonic Master
  • 9,085 Answers
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Jan 02, 2011
The microwave keeps stopping
If you are actually selecting heating time rather than pushing the "quick heat" button, the control board may be defective.
Aug 22, 2016 | Microwave Ovens
Jennair Microwave Shuts Off after 3 seconds
This is usually a defective or loose bottom door switch or that switch's mount is loose, misaligned or broken.
It's usually caused by opening the door while it's cooking instead of hitting "stop" first) or slamming the door or both.
My help file on door switches is here.
May 19, 2013 | Jenn-Air JMV8186AA Microwave Oven
Stops after 2 seconds
Stopping after 2 secs usually means the inverter or magnetron have failed, or worse case scenario both. A microwave can be storing up to 4000 volts even when switched off, so if you're unsure of what you are doing I would suggest that you get an expert to look at it. BSH is the repair section of NEFF 0844 872 8999, the offer a repair plan, where you pay a set amount (Approx 170 pound) which covers your first repair and any further repairs for a year and you can pay by direct debit monthly to spread the cost. The inverter is approx 200 pound and the magnetron is about the same, so it's a pretty good deal as to replace the whole oven is 600-700 pound.
Jan 03, 2013 | Neff Microwave Ovens
Microwave stops after 22 seconds
Not sure what the problem is but I have exactly the same fault with mine. Apparently it's either going to be the inverter, the magatron or both. Cost approx £120 inc callout.
My advice: Get a new one!
Feb 19, 2010 | Panasonic Microwave Ovens
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Shuts off after 23 seconds....
In most cases when the microwave stops @ 23 seconds it's the Magnetron which has failed, and is shorting to earth.
Either that or the magnetron isn't getting the right signal from the inverter board. It gives it 20 seconds to get the right signal or it shuts itself off.
Apr 04, 2009 | Panasonic Microwave Ovens
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
Oven won't heat and shuts down after approx. 20 seconds
Dec 18, 2008 | Panasonic NN-S763BF Microwave Oven
Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Jan 05, 2008 | Neff H5470 Microwave Oven
Panasonic NN-S563 Microwave Oven Logo
454 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
