Question about Refrigerators
In the freezer section there has been frost on everything.
  • 29 Answers
Try lowering the temperature control
Posted on Jan 02, 2011
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
I have a Wood's upright freezer, but no manual. Top section frosted up. What's best way to defrost freezer??
Advance the defrost timer to defrost position. That would be the position when the compressor stops running. If you have excessive frost, I have found the best way to defrost is to remove everything from the freezer and take freezer outside and just open the door. I have even used my garden hose to speed defrost for badly frosted units.
Sep 25, 2014 | Refrigerators
Fridge not cold but freezer fine
Can you see frost buildup on the freezer walls? Can you find the model number around the fresh food section door? If you unplug the refrigerator and then remove the freezer panel that has a fan behind panel do you see this? Defective Defrost Heater
With the freezer panel removed can you tell me exactly what type of frost pattern you have? Can you email me a photo of the frost pattern you do have?
Evaporator Frost Pattern Only Two Rows
Another possible problem is your model may have a Auto Damper
that could be stuck because of frost blocking the damper from opening and closing that regulate fresh food section temperatures. If you need help I will be here to answer so please respond and search for your model number so I can possibly look your model and see what type of other features that can cause the freezer to be fine and fresh food section to be warming up, Thanks Sea Breeze
Aug 29, 2012 | Refrigerators
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Suddenly there is frost covering everything! What
It may not be sealing properly. check to see if a dollar bill will easly slide between the seal and the door. move the food ( and ice) away from the door then test with the dollar again. If it is not sealing clean with soap and watr using a dish brush. test again after drying. The last is to put a small amount of silicone greaseon the seal. The plumbing section section of the hardware store carries plumbers grease.
Aug 17, 2009 | Amana ARB8057C Bottom Freezer Refrigerator
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer has developed some frost in the back
95% OF THE TIME IT IS THE DEFROST HEATER IN THE FREEZER COMPARTMENT. DEFROST FREEZER SECTION BY REMOVING REAR COVER INSIDE OF FREEZER COMPARTMENT AND EITHER LET IT SIT OVERNIGHT OR BY CAREFULLY USING A HAIRDRYER. DEFROST HEATER IS MOUNTED AT THE BOTTOM WITH TWO SCREWS AND A BLUE WIRE ON THE LEFT AND A PINK ON THE RIGHT. PART NUMBER WR51X10101
Jan 03, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
Refrig/Freezer not getting cold
If there is frost on the back wall of the freezer section a defrost is required. Defrost is normally automatic on a timed cycle. If you have frost and you know it is because of the door being open to long with the refrigerator running it could clear the coil automatically in the next 12 hours of operation. If it does not clear the frost from the coil inside the back wall you may require service to check out the timing device, heaters, and defrost thermostat.
Mar 07, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
