Question about Sanyo Cameras
My computer does not recognize the camera anymore, and when I insert the camera's usb cord into my usb port, it says "power surge on USB port. This only happens with my camera, not any other USB device.
  • 747 Answers
It's possible that the sequence or work flow is upsetting the computer, I know sounds odd but, without the camera hooked up the the computer does it appear to be working okay? If so are you downloading (attempting to download) the pictures directly to your computer hard drive meaning not going through the camera programing software? What I'm going to suggest is two things first make a new folder in your "My Documents" I'm assuming you have PC with XP home edition or newer. I use the Year Month Day as file names. Then check make sure your camera has sufficient power for a download. turn the camera off connect the USB cable to the computer then to the camera and turn the camera on. If you get the warrning then shut the camera off and go to plan "B" if no warring what should have happened is the computer sees a new device searches for a driver and connects to teh camera. Sometimes an icon will come onto the desktop with a drive letter maybe a "D" or "F", that file will be the camera memory card file you can open this which should show the pictures files, it'll also show the corrupt files that started this whole mess in the first place. Now click on the top left thumbnail then select all copy then past this in the new folder you just made in "My Documents".
Once there the files can be opened ether in your Windows editing program or the camera editing program(s). Now don't just unplug the USB cable because the camera and or the computer will not like that and cause even more problems, what you need to do is a safe/eject of the device. Once done disconnect the USB cable from the computer and the camera.
Comes the good part now format the camera memory card always format the memory card in the camera in which it's going to be used this cleans the memory card much the same way as defrauding your computer hard drive but in a much smaller scale. You didn't give me the model of the camera so i can give you details of what page in the manual to follow for formatting a memory card.
Okay all that fails because the computer says "power surge" what I'm going to suggest is buying a camera memory card reader the reader is the greatest device made for digital downloads from cameras. It completely does away with the camera buying the right one for your memory card is inexpensive plugs into the USB port and everything is good to go once you insert the memory card into the reader the computer looks at it as an external hard drive and you can download your pictures files into that new folder you made in "My Documents"
Don't forget to format the memory card once you it back into the camera.
Took a short novel to write but believe it or not it only takes a few seconds to download.
Cheers Happy New Year
Posted on Jan 02, 2011
Connect usb port
Check all computer connections and cords. Is the powerstrip for surge protector light indicator bar (usually inside the off/on switch itself) on?
All it takes is a pet to walk over it or a foot to bump a cord and break the power connection. Mine do it all the time. Check the power on/off button on the printer to see if it accidently got powered down.
Sep 19, 2013 | HP Officejet Pro K5400 All-In-One InkJet...
I have a Nikon Coolpix 7900 camera I purchased used. It came without the proper USB cord, so I purchased one separately. When I attached the camera to the USB port of my computer (and I've tried...
I'm afraid that USB port has been damaged and is drawing excessive current causing the error message. You are at least fortunate in that your computers' ports are protected since the camera could have otherwise caused damage. Using a basic multimeter one could probably measure across the pins 1 & 4 to determine if the camera's input is shorted; it should in no case measure less than 5-6 Ohms regardless of lead polarity. The current capability of a USB port varies by version but is between 500 & 900 Milliamperes.
Sep 23, 2011 | Nikon Coolpix 3200 Digital Camera
What does usb device not recognized ?
The best you can do is,
Turn off the PC/Laptop
Disconnect the USB cable from Camera to pc/laptop
Disconnect the power cord connecting the pc/laptop and the wall jack or surge protector
Disconnect the power cord connecting the camera to wall jack or surge protector
wait for 5-10 mins
Connect the power cord of PC/laptop and turn on the pc/laptop and login to your PC
Connect the power cord of Camera to wall jack or surge protector
Connect the usb cable or camera to PC/laptop
It should get recognised and work fine.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 20, 2011 | HP Photosmart R847 Digital Camera
I have a mfc 465-cn and I have another computer and tried to install my printer. once I get to the part of installation where I insert the usb cord into the port and turn on the machine it doesn't...
hello
have you tested all USB ports and with other applications (ie: digital camera, cell phone, USB drive stick, etc..) ?
if one USB does work, buy a USB hub and salvage this working USB port (if that is the case here, that only one USB port on your computer functions) . This will allow you to use other USB ports on the hub . But beware you will have limited useage as to what you can or cannot plug in. USB hubs generate 500mA typically for a 4 port hub, so any peripheral requiring more than 100mA-120mA current downstream may not work on this hub.
if you need the manual to your Brother printer, go to this link and download or save onto your computer
http://welcome.solutions.brother.com/bsc/public/us/ca/en/doc/manual_index.html?reg=us&c=ca&lang=en&prod=mfc465cn_all&dlid=&flang=English&type2=-1
i hope this helps
Nov 12, 2010 | Brother Office Equipment & Supplies
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
Plug USB cord into computer to transfer photos..on camera screen it says mass storage and the USB is not recognized
Plug camera in any other USB port of computer as some time one particular USB port stop to recognize it.
Oct 20, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
Mouse and keyboard not working / recognized by computer
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Jul 02, 2008 | E-Machines T3624 PC Desktop
Helpp! exceeded the power limits on its hub port?
try to change a new USB cord, and if it does not work the problem is a device then
Jun 21, 2008 | Vivitar MAGNACAM Binocular
Camera won't let me upload!
try useing it on another computer you dont have to install sony software to use the camera on another computer if it dose work that tells you that its prob your USB port.
Feb 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Cameras Logo
62 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
