Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have a flo error and i have bypassed the pressure switch due to it being bad but the motor still turens on and off just by giving the hottub power the3 temp is very cold 39 degrees can you help
    Problem Solver:
  • 5 Answers
Could be a bad heating element go to home depot get a volt meter (dont worry its simple to use )
take the volt meter turn it to continuity shut power off put the test wire on the heating element ...Imagine this.. the heating element is like a light bulb the difference is you can see the filament ...you can see if a light bulb is bad because you can see the wires are burned in the light buld (and yes you can shake it and hear the rattle) well on hot tub heaters you cant see the filament or burnt wire so the metre will tell you if its burned out goodluck www.dollarspa.com
Posted on Jan 02, 2011
How do I resolve error code E02 after everything has been checked
check for power on line one and two at the braker.. L1-L2 should have 230 volts or what motor is set to run on, if you have a flo senor try bypassing it
Jan 03, 2015 | Pool & Spa
I have a vita spa hot tub i've replaced the circuit board,heater, preasure switch,check the pump reset the top board but keep getting a flashing flo error and will not heat up.Tested current have 115
I believe with some of manufacturers spas, Vita included, the error will occur if the system is reading that the pressure switch has a "CLOSED" circuit. Bypassing the pressure switch, will still be creating this! What this means to the system: The circuit board does a quick system check. If the board says to itself: "Why does the pressure switch tell me the water is flowing (thats what happens when the pump is on and moves water; pressure is created in the plumbing and the switch then closes) when I haven't even sent power to the pump yet?" Then it will send the error message.
Your switch may need to be calibrated to only close when there is water flowing, and then open within a second of the pump or water flow stopping.
Oct 30, 2014 | Pool & Spa
How do I reset error code on imperial hottub..?
Flo code is not a resettable message. That means you have a problem. Is it flashing (interactive with temp) or is it solid (only the Flo Code) ?
Both of these are two different problems, and they have to be corrected before the message will clear.
Try cleaning the filter, or if it is older than 18 months, replace it.
Nov 21, 2013 | Imperial 7 Person Hot Tub Spa
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Qca Spa pumps and blower will not come on, water down to 35º f
Ken,
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Regards,
Ian.
Feb 07, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Dryer won't stay on
When you turn your start switch it gives temporary power to the motor and then centrifugal switch in the motor kicks in and gives power to the motor until the timer stops it or the door is opened.Your motor centrifugal switch could be bad due to poor contact or heavy linting in and around the motor.Vacuum inside the dryer specially around the motor. If it doesn't fix it you have to buy a new motor, centrifugal switch cannot be bought separately.
May 30, 2007 | GE DBXR463GB Gas Dryer
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
200 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
