Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
NFORMATION
Bulletin No.: 06-08-44-015B
Date: May 12, 2009
Subject: Information on Eliminating Noise in Audio System When Using Portable Playback Device
Models:
2010 and Prior GM Passenger Cars and Trucks (Including Saturn)
2010 and Prior HUMMER H2, H3
2005-2009 Saab 9-7X
Supercede:This bulletin is being revised to add model years. Please
discard Corporate Bulletin Number 06-08-44-015A (Section 08 - Body and
Accessories).
Some portable audio equipment may be susceptible to certain types of electronic noise present in the vehicle's 12V power outlet.
Here are two ways to eliminate this type of interference:
If the audio device is capable of being self-powered (battery), use
it that way instead of plugging it into the vehicle's power outlet.
Have the customer purchase a Ground Loop Isolator, such as *Radio
Shack Catalog #270-054. This device plugs in between the radio and the
customer's audio device. It is packed with one included Y-Adapter. If
purchasing the *Radio Shack product, you will require an additional
Y-Adapter (Catalog #274-369). This device should be installed between
the audio player and the AUX input of the vehicle radio. These catalog
numbers are stocked nationally at *Radio Shack Retail Stores in the
U.S. and are currently available. Other similar products are available
through other electronics or car stereo retailers defined as Ground
Loop Isolators.
Parts Information
Parts are currently available nationally in the U.S. through *Radio
Shack retail locations or through the mail at Radio Shack direct
ordering 1-800-843-7422. In Canada, parts are available nationally
through *The Source By Circuit City retail locations or at
www.thesourcecc.com.
*We believe these sources and their products to be reliable. There
may be additional manufacturers of such products/materials. General
Motors does not endorse, indicate any preference for or assume any
responsibility for the products or material from these firms or for any
such items that may be available from other sources.
