Question about Hotpoint Refrigerators
I REPLACED ICE MAKER UNIT BECAUSE REPAIR MAN TOLD ME THAT THE HUMMINING NOISE WAS DUE TO ICE MAKER BEING STUCK IN A CYCLE. AFTER REPLACEMENT THE NOISE IS STILL THERE. WHEN I SHUT THE ICE MAKER OFF NOISE STILL THERE.IT STOPS WHEN I SHUT FREEZER COMPARTMENT OFF.NOISE VERY ANNOYING. NEED HELP. THE REFIGERATOR WAS PURCHASED DEC 28 2004. IT IS A HOTPOINT 25.0CU.FT. SIDE BY SIDE
    Scholar:
  • 148 Answers
Theres ice in the fan propelar, if you see no ice blocking the propellers its the fan motor itself,if you unplug the fridge and stick something thin between the vents where you feel the air blowing thru and try turning the fan,gently and it spins smooth its the fan motor,if you dont wish to do this turn freezer off,open the door and let it defrost,then plug it in if buzz still there its the fan motor
Posted on Jul 08, 2008
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Thanks for being there. I bought a Whirpool refrid/ freezer on top from a friend and the water pump behind ans at the back of the unit was broken. I had a repair man replace the water pump. What happens is...
If your ice maker was leaking before and after the valve replacement, it is likely the ice maker that is at fault. The ice maker energizes the water solenoid, its not a pump, which then opens to allow the pressurized water flow up to the ice maker. If the valve solenoid has been replaced, the culprit is likely the ice maker itself. The valve should only be open for about 7-9 seconds, but if the ice maker motor is slow, or if there is some other malfunction with the ice maker, it will energize the valve for too long, causing it to then overflow. It could also be a hairline crack in the ice maker mold that is causing it to leak.
Oct 13, 2010 | Whirlpool Refrigerators
Ge monogram ice maker makes loud churning noise. Any suggestions
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Jun 12, 2009 | GE Monogram ZDI15C Automatic Icemaker
Knocking noise
it could be the compressor
Apr 20, 2009 | Refrigerators
AMANA FRIDGE SCD23VBW, NEW ICE MAKER WON'T CYCLE
repairs should be performed by an authorized repair technician. D7824706Q complete ice maker should never be advanced manually. the ice maker arm should be in the down position in order to advance. once the inner thermal switch has been satisfied the ice maker motor should advance. the ice maker is damaged and will need to be replaced by the proper ice maker.
Jun 04, 2017 | Refrigerators
Ice maker cycling but getting stuck
Either you have a bad heating element (soften the ice to eject) or a stripped gear in Ice Maker either way it will have to be replaced by the time you buy the parts and install them you can just replace the ice maker as a unit
May 10, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
120 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
