Question about Cobra CPI 1000 DC to AC Power Inverter
I have the same problem how can you fix it when the inverter keeps saying OLP
My 1500 watt cobra power inverter shows "olp" wuth nothing connected. bought a new one also 1500 watt and as soon as i turn it on shows "olp" also.
Pop is over load protection. You may have gotten a bad inverter. When you do connect something to it does it go away? If so what size wires are you using? To small a gauge wires cause all kinds of problems.
Feb 27, 2017 | Cobra Electronics - Others
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
Oct 22, 2016 | Eliminator Electronics - Others
I have 3000 w inverter now when I turn on its saying olb and fans on back side one
Make & Model? A troubleshooting Hint: Remove & unplug everything from the AC outlet(s), still have the OLP error code? Note: Some 3000W Inverters have two inverter circuits operating in parallel, if one circuit blows its internal fuses maybe its only work on one circuit ? Usually there are a number of 25A car fuse (Qty 8) in parallel for each inverter circuit.
Unless it was overloaded momentarily there should be no reason for the fuses to blow under normal working conditions. That means highly likely they may have blown due to circuit fault.
Oct 22, 2016 | Inverter Electronics - Others
My inverter says OLP?Will run a few mins n turn off. Any ideas or suggestions to whats causing this. So i can fix it
Overload protection circuit cutting in
Something you have plugged into it is drawing too much power or is faulty
Feb 08, 2015 | Televison & Video
I replaced the 35amp fuses with 40s in my 1550 cobra power inverter will that cause the olp code to pop up
The olp overload refers to Watts and the fuse is monitoring Amps! The rule is replace fuses with the same or lower but in this case it isn't causing the olp!
Oct 22, 2014 | Electronics - Others
My 3000 watt inverter says "lup" on the display
This question is solved in detail on a different page here on Fixya by user Pierre Curtis in detail. It's very well written. Rather than repeat, just click this link:
http://www.fixya.com/support/t26322938-3000_watt_eliminator_olp_lup_codes_any 3000 watt eliminator with OLP and LUP CODES any Ideas
Nov 09, 2013 | Eliminator MotoMaster Mobile Power...
How do I remove olp message
Its an inverter DC to AC---what since I do not understand the described problem is the unit doing or not doing?
Dec 04, 2012 | Cobra Cpi 2575 5000-watt, 12-volt Dc To...
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Cobra CPI 1000 DC to AC Power Inverter Logo
46 people viewed this question
Top Cobra Electronics - Others Experts
Gil Shultz
cwradio73
Bill Boyd
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
