Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
I have a Kitchen Aid built in dishwasher. It has always cleaned the dishes beautifully except for the sandy gunk that it occasionally leaves on items, especially glasses and coffee cups. Recently, it has become worse. Have used Cascade for years, including the little pods. What can be causing this problem?
  • 50 Answers
There is a filter at the bottom of the dishwasher where the dishwasher drains. This filter is probably plugged. You may also have a kink in the drainline. The dishwasher usually drains into either a drainpipe under the sink or into the disposal. If your disposal is full this will also cause the dishwasher to not drain properly.
Posted on Jan 02, 2011
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
My kitchen aid dishwasher has an off odor and is leaving a residue on the dishes. what should I do?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Apr 03, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher is leaving a white thick film on my dishes.
Check your inlet water quality. If hardness is noticed add salt as per the directions of the manufacturer. Refer user manual.
Check the rinse aid compartment and fill it with rinse aid as recommended by the manufacturer.
Apr 13, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
White film left on dishes, does not seem to be cleaning thoroughly
could be several things... usually it just needs rinse aid.. all dishwashers spot or leave dishes cloudy without rinse aid.. or your water is just to hard, in that case you will need to soften it with salt, check the owners manual to see how that is done.. also run the dishwasher right after you put the dishes in, if you leave them for a day to wait to fill it up then the dried food gets like cement.
Dec 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
How do I clean the KitchenAid 24 in. KUDI01FLSS? I can't wash dishes until it's cleaned.
Use 1-2 packets lemon kool-aid (unsweeted of course) and run it with no dishes in it.
The citric acid will dissovle most gunk
Oct 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishes never come out clean
Sounds like not getting sufficient water. Replace water valve if that's the case.
Nov 14, 2017 | Whirlpool 24 in. Built-In Dishwasher w/...
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
98 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
