Question about Brother MFC255CW All-in-One InkJet Printer
The yellow won't print at all in test print. It is a new cartridge. The rest print fine.
  • crankybadger Jan 02, 2011
    it is a refilled cartridge from Cartridge World.
When you say it is a new cartridge, do you mean fresh off the shelf with a good expiration date or just opened out of the box? Ink cartridges will go bad in the box sealed and unopened over a period of time. Check the expiration date on the box even if recently purchased.
Posted on Jan 02, 2011
  • cescohsval Jan 02, 2011
    You might want to try a new (not refilled cartridge) Sometimes refilled cartridge ports will clog. Ink cartridges can be finicky.
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
The cartridsge printe red and blue fine. No yellow
The print head for the yellow color may be clogged. Check the manual to see how to turn on your print head's cleaning system. Run it until the yellow starts to print properly. If after running the cycle 4 or 5 times you still can't get any yellow to print you will probably have to take the printer to your local repair depot to have them diagnose the problem.
Jul 11, 2009 | Office Equipment & Supplies
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Stopped printing yellow, worked fine yesterday, new cartridge installed, suspect airlock as no yellow at all.
Try taking your yellow cartridge out and giving it a shake. Also make sure you've removed all the plastic tabs from the cartridge, and test to see if there is any colour coming from it by pressing a damp paper towel against where the ink shoots out. If it still doesn't work I would simply return the yellow ink cartridge to where you purchased it for a new one.
May 06, 2009 | Brother MFC-5840CN All-In-One InkJet...
CLP-300 prints only in blue and black color
If its brand new then it is dead on arrival. you may approach sales department.
if u want to troubleshoot u need to check installation of transfer belt. imaginb unit.
try testing page by pressing continuously cancel button onthe printer.
Dec 25, 2008 | Samsung CLP 300 Laser Printer
Yellow will not print
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 22, 2008 | Brother Multi-Function Center MFC-665CW...
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MFC255CW All-in-One InkJet Printer Logo
83 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
