Question about Dishwashers
GE Potscrubber 1000 with temperature sensor GSD1000M20-Water in bottom at end of cycle
Can anyone help me? DISHWASHER WILL NOT DRAIN
Does it sound like it is trying to drain or is it just silent?
Posted on Jul 27, 2008
I have a GE 1200 Potscrubber portable dishwasher it was running good until it started to drain then water started coming out the bottom is there a way to fix this? Please help me.
You can take the unit and lay it down. There will be some water leakage. You can then see the hoses and connections. Sounds like the drain hose is either cracked or loose.
Feb 08, 2014 | Dishwashers
Dishwasher won't drain at the end of the cycle
Whenever an appliance does operate its pumps/valves heaters correctly for part of a cycle then doesnt at another point, it is a problem with the controller of the sequence in the cycle.. On older devices this can be a rotating knob that slowly runs to end of cycle triggering events as it turns, by tripping blade switches near the rotating item. On these the switch trigger points can be inspected and sometimes repaired. On newer items the cycle is controlled electronically, and you have to replace the whole control unit, which is usually a large expensive part that includes the display and all buttons. Try getting a used control unit from Ebay and swapping it out, or consider replacing the whole appliance.
Dec 14, 2013 | GE Dishwashers
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
My dishwasher does not drain completely. There is
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | GE 24 in. Profile PDW7800 Built-in...
GE Potscrubber will not drain or cycle.
Here is a tip that I wrote that will help you with your problem...
heatman101
May 13, 2010 | Dishwashers
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Dec 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishwashers Logo
317 people viewed this question
Top Dishwashers Experts
