Question about Lenovo IdeaPad S10-2 Netbook
Hi, I have a Lenovo s10-2 and when i researched it before I bought it it said it had an led light for the keyboard, which I really liked with my old thinkpad. For the life of me I can't find it. Any suggestions?
    Guru:
  • 868 Answers
Hi kenax951,
Thank you for choosing Fixya, I see that you are asking where the option for the keyboard light will be on your S10-2 Lenovo Netbook.
I am sorry to say that the S10-2 Netbook does not have that function or light under the keyboard to illuminate the keys.
All Lenovo systems do not have that kind of keyboard, only IBM would have some Laptops that have a light that can illuminate the keyboard.
I have checked every detailed manual and refference regarding the Lenovo S10-2 Netbook but there isn't anything that would specify about a light LED on the keys of the s10-2 keyboard.
mvincentc
Posted on Apr 21, 2011
On my Lenovo g500 laptop many keys(gh and many) are not working, what should I do?
Connect to external usb keyboard to check. If works ok, your keyboard is defective and you should change it.
See tutorial
How to replace or remove keyboard on Lenovo G500 keyboard replacement
How to replace the keyboard of Lenovo g500 g510 g505
LENOVO G550 Keyboard Installation Replacement Guide Laptop Remove Replace...
Lenovo G580 G570 G500 G510 disassembly replacement keyboard hard disk full...
A warning: might look easy but if you are not really familiar with dismounting a laptop, you might end taking your device to a repair shp in a shoebox.
Jul 20, 2015 | Lenovo Computers & Internet
My lenovo e530 few keys stop working due to spill
Go to Amazon.com and search for an aftermarket keyboard for you make and mdl. It would be a cheep fix (most likely under $25.00) if it doesn't come with instructions google replace keyboard and add your make and model. Most keyboards are held in by 4 or 6 screws accessed on the bottom of your computer. After you remove the screws open the computer and lift the old one carefully until you see a ribbon (flat wide wire) of cable there will be either a connector on the end that will lift out or at the computer a plastic connector attached to the computer that has a piece that will click away and the ribbon will come out. Put the new one in and put the screws back. Reboot and cross your fingers. Or you can use a USB or wireless keyboard, but that's not to portable.
Worst case get into the virtual keyboard thru access ability settings and you can use the mouse to type the letters your keyboard will not type. Good luck, Kevin
Aug 03, 2014 | Lenovo ThinkPad Edge E530 325978U 15.6"...
My led indicators for caps lock num lock etc not workinh in my lenovo G570 laptop
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected to your CPU, then depending on your keyboard model, you may have to turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
Jan 26, 2013 | Computers & Internet
My lenovo G560 model 0679 keyboard rightside number keys 2 5 8 / etc do not work
Im sorry to hear that, if its really a hardware problem, what you can do is to replaced the whole keyboard since Lenovo do not send out parts for just a particular key on the keyboard. If the system is still under warranty, you can try to contact lenovo and they will process depot for you.
Hope this will help... Your response is very much appreciated...
Jan 23, 2011 | Computers & Internet
Keyboard not working
For a cheap solution, have you tried plugging in a regular keyboard?
Likely, the real problem is a loose ribbon cable under the keyboard. It is a bit messy to open open a laptop. So, if you can get by with an external keyboard, it might be the best solution.
It has been a while since I opened an IBM/Lenovo. Some laptops are easier than others to replace the keyboard.
May 23, 2010 | Lenovo IBM ThinkPad T43 Notebook PC -...
Info req'd on user part of linova r61e thinkpad
Some Lenovo and ThinkPad computers have a LED light that is located on the top edge of the screen and can shine a light on the keyboard.
To switch on this LED light, press the Fn key plus the PgUp key (This key maybe different on some model laptops).
Feb 21, 2010 | Lenovo ThinkPad R61e Notebook
Problem with keyboard
When you hook an external keyboard to it, does it type normally? I am guessing it probably does but you need to test that first. Find a USB keyboard, hook it to it, wait for it to start working and check it out.
If the external keyboard types normally as I think it will then you probably need a new keyboard. If however your computer was damaged by moisture or unnatural compression to the keyboard, a new keyboard may not fix it. Moisture damage or compression damage to the computer can be permanent, but my first guess is a keyboard would do the trick.
Taking the keyboard off a Lenovo (less than 4 years old) is very easy. There about 4 or 5 screws on the bottom that need removed and the wrist rest (which pops out) then they keyboard comes out pretty easy.
Jul 31, 2009 | Lenovo IdeaPad Y430-3231U Notebook
Lenovo 3000 v100 keyboard problem
sound like a connector problem .. see this website for the removal instructions
http://www.lenovoservicetraining.com
Dec 10, 2008 | Lenovo ThinkPad T61 Notebook
Sounds like your keyboard is either not connected securely or it is faulty.
Aug 04, 2008 | Lenovo 3000 V100 Notebook
Lenovo IdeaPad S10-2 Netbook Logo
277 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
