Question about Craft Master 4400 Mechanical Sewing Machine
The thread is tangled and extra thick on the bottom of the fabirc when I stich
How do I adjust the sticth tension and length for sysnergy of top and bottom sewing
  • kalquist Jul 08, 2008
    I cann not seem to get an even stitch- the thread is bunched and too loose on the bottom and I don't know how to adjust the sticthes?
  • 323 Answers
Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
If it passes this test you need to remove the bobbin case and check for burrs or rough spots. If you find any ,use an emery stick to remove them and then buff the area with fine steel wool.Put the bobbin case back in ,check your bobbin(change it ) and try again by turning the handwheel slowly and watching to see where thr thread is snagging
sewman7
Posted on Jul 08, 2008
The thread on my Janine3-18 is getting tangled on the bottom of tho sewing
usual if thread tangles on the bottom is that you top thread tension need adjusted try on a piece of scrap material and adjust your tension until the stitches are even top and bottom hope this helps you
Feb 11, 2015 | Sewing Machines
How can I fix the top stich
I like to adjust with 2 colors, then you know which is from the spool, and which one is from the bobbin.
Most bobbin shuttles have a small screw to adjust the tension.
It sounds like your upper thread is adjusted too tight, but only if the loops around it (from the bottom thread) are tight and small. If those loops around the top thread are loose, then you need to tighten the shuttle screw. ;)
I notice this happens to me if I change thread types, also if I sew different thickness of cloth on the same settings. I tend to adjust until the point of breaking thread, then loosen the top a teeny bit.
Sep 06, 2014 | Sewing Machines
Bottom thread tangles and knots
usually a top-thread tension issue, try tightening up the top thread's tension, there is usually a disk or knob somewhere to adjust it.
Dec 10, 2013 | Sewing Machines
I am having a problem with my bottom sticth. It is all bunch up. But the top sticth is okay. What is going on?
Have you checked that the bobbin thread is correctly into tension? It sounds like something is not right with your tension and the bobbin thread is either not in tension or the thread on the bobbin is tangleing and not flowing smoothly, causing the pulling up.
Either way, you will need to remove the bobbin, take a good look at it and see if it is wound smoothly and neatly (rewind if not), and rethread into tension device.
There is good tips on adjusting tension here http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
Jul 21, 2011 | Sewing Machines
Top thread is knotting up on the bottom even if I switch out thread or bobbins. seclector is on A length is on 2 and width is on o
It sounds to me as if your top thread tension is too loose or your bobbin thread tension is too tight. The top thread is tangling underneath and is probably making big loops. Consult your owners manual on how to adjust thread tensions.
Good Luck!
Chris
glfi.com
May 22, 2011 | Sewing Machines
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
Back of stich looping tried tightening tension went up to the limet with no diference
You do not have your machine threaded properly. Totally rethread your machine, make sure that your thread is not tangled and your needle is not bent. Also, make sure you have the thread compatible top and bottom.
Sep 17, 2010 | Sewing Machines
How to adjust tension the underside stich is loose and tangled, the top stich is fine
Usually it is your top threading is not right, double check that. Read you manual carefully, even if you think you know how to thread it, do it over again. Good luck
Jul 24, 2010 | White Sewing 935 Mechanical Sewing Machine
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Looping thread on backside.
I have a 26 year old Elna and this is the only weakness it has. Before sewing, try this. Turn the wheel manually and watch the upper thread pick up the bobbin thread. Pull both back to the left. Make sure they are plenty long. This helps me prevent the tangling in the dogfeed. My Elna has a universal tension on the bottom and I haven't ever had a problem with it unless the top tension is too tight.
Apr 07, 2008 | Elna 1010
Craft Master 4400 Mechanical Sewing Machine Logo
122 people viewed this question
Top Craft Master Sewing Machines Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Craft Master Sewing Machine Expert? Answer questions, earn points and help others
