The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Depending on the kind of grinding noise your hearing, it could be a number of things.If your dryer has been doing this for quite a while it could be that the front and/or rear felt have become worn or broken. if these are gone the drum will make contact with the inner rim of the door and the back portion of the dryer part number for both front and back tumbler seals is 33001807. If however the noise you are hearing has just recently and suddenly happened, this could indicate that possibly something has got caught inside the these same felts or seals. If the noise you are hearing is more of a loud buzzing this could indicate that something has obstructed the blower wheel inside the dryer, and is now rubbing against the fan blades of the fan. part number for the blower fan can vary depending on your SERIAL number. If you want to take a look insaide your dryer. FIRST UNPLUG IT. then with the door removed there should be two screws at the bottom of your unit. once removed you can now remove the "U" shaped bracket around the base and door. now you will be able to see inside. if you need to lift the top there are two screws at the left and right sides that hol brackets to the top. remove these and you now have access to the whole dryers drum, heater etc. Hope this helps
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction.
Gerard
