Question about Kitchen Ranges
What is the y-intercept of a line with an equation 8x-8+2y=0?
  • 8,220 Answers
8x - 8 + 2y = 0
8X + 2Y = 8
y = -4x + 4
X = 0 por y-intercept
y=mx+b
Y = 8/2 or 4
Knock knock
Who's there?
4 who?
Why yall want me to do yall's homework 4?
Do the math on that! LOL
Posted on Jan 02, 2011
Testimonial: "thanks :D and one more question.... what is y=-3x-4 "
  • Dan Webster
    Dan Webster Jan 02, 2011
    FYI:
  • Dan Webster
    Easy peasy can you verify this for me fist please:
    y=3x 4
    3x=4-y
    x=4-y/3
    Hint:
    slope is 3/1
    y is 4 OR
    How can yall plot the points
    if yall don't eat yall's puddin?
How to solve and graph the equation 4x+y+0
The easiest way to solve and graph and equation is to put the equation into the slope intercept form y = mx + b, where m is the slope and b in the y-intercept.
To do this, we subtract 4x from both sides and get y = -4x + 0.
From this we know m = -4 (slope) and the y-intercept is 0.
I always start with the y-intercept and put a point there. Thus, we have a point at (0,0). Using this as a starting point, we now use the slope of -4 to get future points. Since it is negative, we go one unit to the left and up four units. So we have the point (-1,4). Using a ruler, we connect these points and continue on both sides to produce the line.
There is also a great free online program/app called Desmos that you can use to check your work. Type in the equation of the line and it will graph it for you.
Good luck,
Paul
Oct 27, 2016 | Office Equipment & Supplies
How do I graph 4x+y=0
Good luck,
Paul
X and y intercepts
First of all you equation is not one : it has nothing on the right side of the = sign. But to answer the general question let us write the equation as 50+25x-5y=0
X-intercept (also know as roots) There may be several
Definition: X-intercepts are those values of the independent variable x for which y=0. For a straight line there con be at most 1 x-intercept.
To find the intercept, set y=0 in the equation of the line and solve for x
50+25x-5(0)=0 or 50+25x=0. The solution is x=-(50/25)=-2
Y-intercept (also know as the initial value. There can only be 1 y-intercept, otherwise the expression does not represent a function.
Definition: It is the value of the dependent variable y when x=0 (where the function crosses the y-axis
To find it, set the x-value to 0 in the equation of the line.
50+25x-5y=0
50+25(0)-5y=0, or 50-5y=0. The solution is y=50/5=10
The straight line cuts the x-axis at the point (-2, 0) and the y-axis at the point (0,10)
Jan 28, 2014 | Computers & Internet
-6x-3y=27
The x intercept is where your line will cross the x axis. Therefore, the value for y at this point is 0. Substitute 0 for y in this equation and solve for x.
6x + 3(0) = 27
x = 27/6
x = 4 1/2
x intercept = (4 1/2, 0)
Follow the same reasoning for the y intercept.
6(0) + 3y = 27
y = 27/3
y = 9
y intercept = (0,9)
Now plot these two points and draw your line through them.
May 18, 2012 | SoftMath Algebrator - Algebra Homework...
How do I use this calculator to find the x and y intercepts when the problem has both the x and y letters. it will not allow me to enter the full equation. example problem is 2x-5y=20 and I need to find...
x-intercept (or zero of the function)
Set y=0 in the equation and solve fo x: 2x-5(0)=20 and x=20/2=10
y-intercept (initial value)
Set x= 0 in the equation and solve for y: 2(0)-5y=20 and y=20/(-5)=-4
If the equation is in the slope-intercept form y=ax+b
1. y-intercept is b
2. To get the x-intercept ( zero of the function) Set y=0=ax+b, and x=-b/a
Aug 27, 2011 | Texas Instruments TI-84 Plus Calculator
Can i ask how to answer this?2x-4y-9=o
That is an equation describing a straight line. The "slope-intercept" form of a line is
y = mx + b
where m is the slope (change in y-value / change in x-value)
and b is the y-intercept (the point where the line crosses the y-axis when x=0)
Positive slope means the line is rising and negative slope means it's falling.
You can rewrite the original equation 2x - 4y -9 = 0 in slope-intercept form:
y = (1/2)x - (9/4)
So you know the slope is positive 1/2 (line rises 1 y-unit for each 2 x-unit change) and crosses the y-axis at -9/4. With this information you can graph the line.
Jul 12, 2011 | Sewing Machines
Find an equation of the line containing the given pair of points (-6,0) and (0,1) what is the equation of the line? y=
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=1, y1=0, x2=0, and x1=-6. You should get a=(1-0)/(0-(-6))=1/6
The y-intercept is the y-cordinate for x=0. Its value is 1.
The equation is then y=(x/6) 1.
Oct 18, 2010 | Texas Instruments TI-84 Plus Calculator
2x+4y=8 find x intercept and y intercept
Have you graphed the equation? Are you asking someone to solve and give you the answer or tell you how to use your software?
Jun 19, 2009 | Mathsoft StudyWorks! Mathematics Deluxe...
(-4,6), m = 8
The equation of a straight line is given by y=mx + b where y if the y intercept on a graph and x is the x intercept on a graph and m is the slope of the line
Using the given information of ( -4, 6), m=8
-4 is the x intercept, 6 is the y intercept and the slope is 8.
Plugging these values into the y = mx + b gives 6 = (8) (-4) + b solving for b gives b = 32
Going back to the original equation of a straight line gives the equation of y = 8x + 32
Hope this helps Loringh PS Please leave a rating for me Thank you
Nov 19, 2008 | SoftMath Algebrator - Algebra Homework...
Kitchen Ranges Logo
173 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
