Question about Whirlpool AWZ7303 Electric Dryer
My Whirlpool Awz7303 condensing dryer keeps tripping the breaker during the cycle. I have checked the folowing: 1. Breaker is perfect 2. Wiring is perfect 3. I replaced the thermostat(s) 4. Drum seem to be turning without problems, therefore I don't think there is a fauty bearing putting stress on the motor. Any other suggestions??? Please help
  • kieran_o_far Jan 02, 2011
    I have already tried a different breaker so that is why I know the breaker is perfect. In fact I moved house so it is a completely different house not jsut a different breaker. I will check the amp draw as you suggest what is considered too high?
  • 1,998 Answers
When a dryer trips the circuit breaker, it will suddenly power down. Any devices connected to that particular outlet will also suffer from a sudden loss of power. It this occurs every time the appliance is used, the dryer is tripping the circuit breaker. The first potential area of trouble could be that the dryer has a defective thermal resistor. Dryer thermal resistors control the heater in the unit. If the thermal resistor is defective, it will not turn off the heating components in the dryer, which will cause the dryer to continually heat up. As it keeps heating, it keeps drawing power, which will trip the breaker. If the user is comfortable with dryer design, he should check the thermal resistor (also known as the "thermsistor") for damage. A thermal resistor is about the size of a nickel and is located in the heating element. Remove the dryer connections to it and test its conductivity with an Ohmeter. If there is no reading, the resistor is defective and needs replacement.it is also a rear happening but i have also seen two seperate instances where a power wire was frayed that went to the motor and was arching against the cabinet floor and i have also seen a timer wire that came off the timer that was arching against another as well also is the breaker a 30 amp breaker?also does it trip instantly how long does it run before it trips if you have any further questions please message me back and please remember when our chat has concluded to rank how this opinion has helped Thanks again Rick
Posted on Jan 02, 2011
    President:
  • 2,468 Answers
Check the amperage draw on the unit with an amprobe or current meter when the element cycles on to heat and see what its drawing,then if too high of current draw you may have an element starting to short out to ground on the elements case,otherwise if not,try a different tandem circuit breaker(30) amp as they can get weak and trip during the heating element cycling on and off
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor · Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
My dryer does not heat. how can i fix it?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 15, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not start
Hi
Hope this helps...
Daniel
Sep 14, 2010 | Whirlpool GEW9200L Electric Dryer
Not heating up
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Post back if more assistance is required. Hope this helps...
Daniel
Sep 03, 2010 | Whirlpool LER4634J Electric Dryer
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My whirlpool washing machine wont turn on. I checked the fuse and the socket which are working perfectly well. It doessnt seem like there is any power in the machine.
1) Check to see if your door switch is working
2) Check to see if your getting any power to your machine with another cycle
3) check to see if breaker isnt tripped
Jun 17, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool AWZ7303 Electric Dryer Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
